Orchard Audio and Soundfield Audio Unveil 1200 Watt 4-Channel Plate Amplifier at NYC International Audio Show
Orchard Audio, in collaboration with Soundfield Audio, is proud to announce the debut of a revolutionary new product at the NYC International Audio Show: a 4-channel, 1200 watt plate amplifier with integrated DSP.
A plate amplifier is essentially a self-contained power amp module, typically mounted directly onto the rear panel of a loudspeaker enclosure. It integrates the amplification circuitry, input connections, and a DSP with crossover controls into a single, compact unit. For the listener, it means fewer boxes, shorter signal paths, and a more direct connection between source and transducer (driver). By embedding the amp into the speaker cabinet, designers can optimize the amp-speaker synergy, especially in low-frequency reproduction where damping factor and driver control are critical.
Orchard Audio’s cutting-edge plate amplifier which uses our award winning Starkrimson technology marks a significant leap forward in active speaker design, delivering precision control, immense power, and advanced signal processing—all in a compact plate-mounted form factor. Engineered to meet the demands of high-fidelity enthusiasts and professional audio environments alike, the amplifier offers:
  • Four independent channels of amplification for complex multi-driver configurations
  • 1200 watts of total output power, ensuring dynamic headroom and low distortion
  • Integrated DSP for tuning, and crossover management
  • Modular architecture allows for future firmware updates and customization, giving users long-term flexibility and performance enhancements
The plate amplifier will be installed in a Soundfield Audio 1212C full range cardioid loudspeaker. This speaker features:
  • Wide dispersion planar super tweeter
  • 12-inch Neodymium coaxial point source main driver with ring radiator compression driver
  • 2 x 12-inch subwoofers
  • DSP Delayed diffuse field rear firing planar driver.
“The 1212C is a bold step toward redefining what cardioid loudspeakers can achieve in both studio and live environments,” said Leonid, founder of Orchard Audio. “By embedding our most advanced plate amplifier directly into the cabinet, we’re giving users unprecedented control and clarity—without the complexity.”
Orchard Audio will be in room 107 at the NYC International Audio Show, taking place from October 24 to 26, 2025. The PecanPi+ Streamer Premium Orchard Audio’s Roon-ready streamer will also be at the show.
About Orchard Audio, LLC
Orchard Audio specializes in designing and manufacturing high-performance audio equipment. Founded by Leonid Ayzenshtat, the company blends advanced technology with meticulous craftsmanship to create amplifiers, DACs, and more, all aimed at delivering unparalleled sound quality for music lovers worldwide.
www.orchardaudio.com
There has been a change to the room number at the show; it will now be room 108
I won’t be at the NYC show, are you going to be at Capitol Audio Fest in Nov?
Yes I will be at CAF, but will be doing something very different. For CAF I am partnering with SVS and we are doing either a 5.2.2 or 5.2.4 ATMOS system.
Cool. I will make sure I drop by.
