Playback at double speed
macOS Monterey 12.6.5
Mac Pro (Late 2013)
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Roon version 2.0 (build 1272)
TrueSpeed Fibre
Orbi mesh network
Core and Endpoint both wired connection to the same switch
RoPieee 2023.04.01 running on Pi4. Optical connection to Chord DAVE
Roon Bridge Version 1.8 (build 1125)
9000
Playback has just started at double speed. The DAC is showing the data rate as being twice the rate of the track. This is happening for all tracks and started part way through the day.
I have power cycled everything except the Core (I have restarted Roon on the Core)
I just reconfigured the RoPieee and it is now fine. I remembered from a while back having the wrong HAT configured can give this problem. I had the right HAT configured according to the config page but selecting a different one then reselecting the correct one solved the problem.
