Playback cuts out repeatedly at the same point in the same song (in thiss instance Sea Power - Two fingers)
MacBook Pro
Wifi
USB into QUAD Vena II
2.500
Playback cuts out repeatedly at the same time in the same song (Sea Power - Two fingers) replayed three times, same problem, skip the song, the playback resumes normally
Is the track local or streamed? If it’s local does it play without issues in another app? If it’s streamed does it play fully in the native streaming app? Just checking it’s not a bad file.
Hey @Maximilian_Grut,
First off, welcome to the community! We’re excited to have you here and look forward to helping you get to the bottom of this issue. @killdozer is steering you in the right direction by first ensuring the file itself isn’t corrupt.
If it isn’t a local track, and you’re only hearing the issue through Roon, then we’ll need a bit more information on your setup, specifically your OS and any additional information on your Core machine, as well as your network configuration.
We do tend to lean on the side of caution when your core is connected to your network over wifi. If at all possible, I would definitely suggest hardwiring your core via ethernet.
I’ll be monitoring this thread for your reply :pray:
