Operation System Version 1.0 (build 227)/Server Version 1.7 (build 667)
Xfinity high speed cable router. NUC is connected via CAT 5 cable. All endpoint devices are wireless.
Various endpoints that are affected by the issue equally
Several times a day, all wifi devices lose connection to the ROCK, which is a recently built Intel NUC8i5BEK with a 500 GB Samsung 970 EVOPlus and 32 GB DDR4-2400. NUC video output is hooked up to my TV on HDMI 3 so I can monitor it. Even when I lose connection, the display continues to show that ROCK is running with an IP address of either 10.0.0.25 or 10.0.0.27 (will change sometimes after I force a reboot). Forcing a reboot always brings back the ROCK on all wifi devices until I lose it again, which is typically not more than a few hours.
I am running an external 500 GB USB 3.0 2.5" HDD for my personal music files. Also running Qobuz and Tidal via subscription. No other devices are connected to the NUC.
When all devices lose connection to the ROCK, sometimes Fing will find the ROCK and sometimes it will not. When the devices lose connection, I also lose the ability to get to the ROCK via the IP address. A reboot always solves the problem but this is obviously quite frustrating. Any help would be appreciate.
Thank you.
Update: Just lost connection to my ROCK server while listening to Roon on my TV that is connected directly to the Xfinity router via CAT 5. The other device connected to the router is the NUC. The music stopped suddenly and I did troubleshooting. Tried restarting router with no luck. Tried disconnecting attached USB drive with music files. No luck. Tried disconnecting CAT 5 cable from NUC with no luck. Screen still shows that the NUC is running with IP address of 10.0.0.25 but I cannot reach that address on any devices and Fing shows the ROCK is offline. I then did what I always do, force a hard reboot of the NUC which immediately solved the problem. Could this be an internal problem with the NUC?
I think the next step here is to enable some diagnostics on your account so our technical staff can get some more insight into what’s going on here.
First, can you please reproduce the issue once more and note the time at which the problem occurs. Then respond here with that time, and I’ll make sure we review the diagnostics related to that timestamp.
Hi Dylan. Just lost the connection on all devices at approximately 09:02:20 EST on Nov 24, 2020. Both my wife and I noticed it on two different devices running different music streams. A hard reset of the ROCK immediately brought everything back up. Thank you.
I have enabled diagnostics on your account so our technical staff can get some more insight into what’s going on here. The next time your Core is active a diagnostics report will automatically be generated and uploaded directly to our servers
Hello @Gooey, I received your report and took a look around the timestamp you posted. I found what looks to be DNS related networking issues so I wanted to know what DNS you are currently using, if your NUC is operating well outside of this issue, and whether or not you can reach the WebUI when the issue occurs. Please let me know!
Hi @nuwriy, When the issue happens, I cannot get to the WebUI. I have installed Fing on my iPhone and when it happens, the NUC appears offline. I use Xfinity for my cable. Network shows the following:
Netmask 10.0.0.0/24
Gateway 10.0.0.1
Local address 10.0.0.108
DNS 0.0.0.0
ROCK is currently assigned 10.0.0.25 but sometimes it’s 10.0.0.27 (assigned dynamically)
Hi @nuwriy, At 5:09 PM EST, lost connection to ROCK. This was after having switched to Cloudflare DNS 3 hrs ago. When I checked the NUC display, it was a page full of text I have not seen before. I waited for a few minutes then did a reboot and ROCK is back up.
So I am confused about something. When asked by @nuwrly to change to Google or Cloudflare DNS, I looked up how to change DNS on my Mac and subsequently went into Advanced settings and changed it. I then decided to check to Xfinity app to see what it says about my network. It reports that the DNS Server is as follows:
DNS Mode DHCPv4
Primary DNS 75.75.75.75
Secondary DNS 2001:558:feed::1
Seeing this made me think I have to change the Ethernet DNS, so I disconnected the CAT 5 from the NUC and attached a MacBook to it instead. I then changed the Ethernet DNS setting to 1.1.1.1 and 8.8.8.8
I guess I’m confused. Do I need to call Xfinity and have them change the DNS?
Lost connection to the ROCK again last night sometime between 9:00 PM EST on 11/27 and 5:50 AM on 11/28. Checked Fing and the ROCK showed it was offline. For what it’s worth, my new PecanPi Ultra, installed yesterday, did indeed show it was still connected to my network and it immediately connected to the ROCK upon reboot of the NUC. Thanks.
At 5:36 PM EST on 11/28, lost the ROCK while listening to Roon. Checked Fing and it showed ROCK was offline. A forced reboot immediately brought it up again.
At 7:49 PM EST on 11/28, lost ROCK again while listening to Roon. Fing shows ROCK is online this time but I cannot connect to it via any device or via the web IP address.
