Hi! Happy New Year! Normally I have two squeezebox touch running. Unfortunetly one power supply doesn’t work anymore. There is no ambition from my side to pay a lot of Money for a high end Power supply but it should be a decent one.
Any advise?
Cheers Christian
IIRC, my Squeezebox used a walwart. Since you have two, post details (photos) of the rating etc., so an alternative can be suggested.
Use the iFi iPower2. It is a bit more than more basic plug SMPS but should work well and be reliable.
Hi Christian, happy new year.
You’ll get a few low cost suggestions in the squeeze box community…
Thanks! It will be that one https://www.digikey.de/de/products/detail/ideal-power-ltd/25HK-AB-050A400-D56-1/12818259?s=N4IgTCBcDa4BxzAWjAVgBIGkkEEBCSADKoTgCyGFIAiqAbEgIxIBy1IAugL5A
That one hasn’t worked. This is perfect https://www.digikey.de/de/products/detail/mean-well-usa-inc/GST18A05-P1J/7703604
but I needed an adaptor from 5,5 x 2,1 mm female to 5,5 x 2,5 mm male.
