I had not expected much difference, but the SQ definitely improved. Better defined bass, and more details especially in the mid-range. But I will listen to it for a few days and then switch back and report.
Please do! Iāve borrowed one from my dealer and itās not going back. I like its sound better though when hooked to my Schiit Magni 2. The sound is very good with both my Hifiman He-500 and HD-650. Definitely a keeper.
Did some comparison between the linear power and the iFi iPower, and the linear power adds a little clarity, better defined sound and a quieter background. The difference isnāt huge but its there. It reminds me of when I removed the cover for the speakers, it gave a similar SQ increase.
And as mentioned, this is in comparison with iFi iPower, compared to no external power at all the difference is very big.
Just got my new S2 Digital and had a question for you guys. For those using it with external PS or USB power - are you letting it run 24/7? Any issues with burn in on the Display? Itād be nice if Pro-Ject added an option to put the screen to sleep.
Hi Magnus, Iām sure itās the same thing inside, different case and LCD screen. Soundsā¦too early to make a comparison as Iām still in the placebo stage I do seem to be more stable and have no MQA dropouts as I was having previously.
Hi Nick, JohnW (designer of this unit) says best performance is USB input and separate linear power supply (or battery) into the USB power port. Thatās what Iām doing.
PS @Magnus I used the iFi for a short while but it was causing horrible grounding issues with my Amp when powering the S2 so I sent it back.
The manual is wrong, the DAC has auto-switching power and will use the external power if present. Even the supplied cheap PSU gives an improvement over USB power (at least for me).
This DAC needs good power to shine, which is why they added the extra power input and auto-switching according to John.
I noticed something else with my linear power: good recordings sounds awesome, but itās easier to hear the shortcomings of bad recordings. I am not sure this is 100% a good thing, but the SQ is very revealing for me now.
I use USB from computer, through an iFi nano iUSB3 to the DAC, and then the linear power connected to the micro-USB. You can see on the DAC display when it gets external power (a green symbol up to the left).
I am not sure the iFi nano iUSB3 helps though, the DAC has good USB signal handling inside. I will experiment and try without it later.
@Anthony_Bristol, did you have to specify in the order that you need larger Mating Plug Size 2.5mm x 5.5mm for USBRIDGE, or correct one was included by default?
