I cannot connect Roon with my Cambridge Audio EXN 100. The screen says: Roon Ready. Open the Roon app and select EXN 100 as your Roon output device. But when I open the Roon app on my pc or iPhone there is no place (that I can see) to select EXN 100 as my Roon output device.
Hello @Buckner_Brown and welcome to the forum.
Did you setup your device? Does setting it up not work and if yes, at what stage? See also:
Hello @Buckner_Brown ,
Thank you for reaching out to Roon Support.
Before you’re able to play audio through a specific output, you’ll need to enable it under Settings → Audio. Would you kindly follow the instructions provided by @BlackJack regarding this process, and let us know if it helps?
We’re here if you need any further assistance.
Hi @Buckner_Brown,
We haven’t seen a response on this thread, but the most recent diagnostics to automatically reach our servers indicates that a device matching the Cambridge you’ve mentioned is now associated with your account.
Are we correct in assuming that you can now see and connect to this Zone in Roon Settings → Audio? This thread will remain open for another day in case you require further assistance. Thanks!
This topic was automatically closed after 12 hours. New replies are no longer allowed.
