Roon+Apple Airport+iMac+Devialet with 192 kHz DAC.
Hi …
When I play 96 kHz/24 bit music format at this time, the sound will be muted and connected during playback! To correct this, I need to fix the disturbance in this setting on sample rate conversation.
Hi Dear / My iMac connected to Apple airport and then connect to Devialet with Ethernet (CAT6) Cable.
My iMac is: 27", 3.2 GHz Core i9, 2019, 32 gb Ram with Mojave OS
I don’t know, unfortunately Devialet Driver (3.0.4) not active in my iMac
Can you please share a screenshot of your Roon Settings -> Audio tab? Do you see multiple drivers listed for your Devialet there? Is the behavior the same when you use both?
Thanks for those screenshots. I’m not seeing a model number listed for your Devialet in the screenshots, can you please confirm which model number you have? It is possible that the model you have only supports Devialet Air.
One thing I noticed in this screenshot:
You appear to have quite a few watched media folders pointing to the same Roon folder, was this done on purpose?
It would be more efficient to add just MUSIC as a watched directory to Roon instead of the individual sub-folders.
