Include your operating system and machine info (Model, CPU, RAM)
Your network gear (model of routers/switches) and if on WiFi/Ethernet
Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.)
Tell us how large your music library is, eg. “30,000 tracks”
Dear ROON users,
I’ve been using ROON for about half a year now and I keep having problems playing music.
First, I have the following hardware that I use for playing the music.
1- Netgear NAS with four drives of 6TB each containing all my albems. (library).
2- Cirrus 7 Nimbini with ROON installed on it. (LINUX)
3- Auralic Aries G1 streaming transporter
4- Samsung tablet with the ROON app.
My modem is in bridge mode in my meter cupboard and I have installed Unifi routers throughout the house.
So the Auralic Aries streams the music wirelessly.
Now it is the case that when I play music, it plays music for about 1 to 2 minutes and then the music stops playing and a text appears at the bottom where the time bar is located (An audio file is loading slowly. This may indicate a performance or hardware problem). What problem could this be.
Very occasionally I can listen to music for an evening with none of the above mentioned problem.
I have the latest updates installed so I don’t think it could be that.
Can someone tell me how this is possible and what the solution is
thanks in advance
