I have a problem with Roon not loading on my Windows 10 computer.
I have Intel Core i5 3,70 GhZ.The initial quatation side appears but nothing more.
The problem started when I closed down Roon because it was very slow when I tried to delete an album.
Hello @Robert_Lidstrom, does Roon just close after the quotes pop up, or do you see any error messages?
Please use the directions found here and send us over a set of logs using a shared Dropbox link and our team will take a look. Thanks!
Hello Dylan
Roon just closes directly after the quotation pop up.
Below you find the link to the “ logs” folder.
Kind regards
Robert
Hello again,
Problem solved.
By mistake I plugged in the DVI-cable to the motherboard instead of the CPU.
So fully enjoying Roon again !
Kind regards
Robert
Hi @Robert_Lidstrom,
Thanks for letting us know you were able to resolve this one!
If you need any assistance in the future with Roon, please just let us know.
