20Gbps fibre backbone from core to Dell X1052P enterprise switch.
WiFi - Ubiquiti UAP-AC-Pro X 3 via GbE wired connection to Dell X1052P
Bluesound Node 2i - GbE
RPi4B - GbE
Various Sonos devices. Playbar and 3 X Play:1 over ethernet
4 X Play:1 over WiFi
BBC Radio2 AAC 320 plays just fine over Ethernet connected devices - Bluesound Node 2i and Sonos speakers. Over the WiFi connected Sonos devices, it pauses every few seconds, then restarts, then pauses. WiFi speed tests are 40Mbps down, 30Mbps up over 2G WiFi connection which the Sonos connects to.
I would appreciate any insight into this. It’s strange that it’s specific to WiFi. Is this a SonosNet implementation issue or an issue with AAC encoded streams? I can play a 96/24 flac from my library to the same WiFi devices, which Roon downsamples to 48/16 without any issue.
Many thanks. The Radio Paradise streams work just fine. It’s most perplexing that BBC Radio 2 has issues, but only over WiFi connected devices. The wired devices are just fine
I have Core running Rock on NUC over Ubiquiti network and wireless APs
I have exactly same issue playing BBC radio stations to Sonos Amp. ie play back stopping after a period and needing restarted.
I have not tried to play to Wired Sonos endpoints so cannot report there.
I have no issues playing BBC stations through Naim Dac V1 connected to iMac.
No issue when playing Radio Paradise AAC stream or flac stream through to Sonos Amp
I haven’t found a solution to this yet. Radio 2 plays fine from Tune-in, though obviously it’s a lower quality stream. Other high quality radio streams play fine via WiFi and I can stream HD stuff from Qobuz/local library via Roon which Roon downsamples to 48/16 with no issues.Bluesound Node 2i is fine with Radio 2, though again, it’s a wired connection.
Apologies if I’m in the wrong thread. All BBC stations I play to any of my Sonos speakers cut out persistently. If I switch to the Sonos app they play with no issues.
Thanks so much for describing in such detail what you’ve discovered about the interruption in playback. Sorry about the trouble and, most of all, for our delay in replying. As you might know, we’re working our way through an unprecedented number of requests and it is taking us much longer than we had hoped
One of our technicians will get back to you on this thread. Please, bear with us just a while longer
