Dear Sir/Madam,
I’ve been a user of the free version of your medial player and recently a problem has occurred. I cannot play DSD256 media files ( it downgrades them to DSD128 ). I think all my settings are accurate and my DAC (Northstar Supremo DAC) does support DSD256 on other players (such as Foobar 2000), What may be the issue?
I just tested with iFi iDSD DAC and I’m ablue to playback DSD256 without conversion to a lower rate. Most likely you set settings which forces Roon to do that conversion. Here are the places we need to look at:
Can you take a screenshot of the signal path when downsampling of the DSD256 is happening ?
Do you use DSP - if so, can you provide a screenshots of your DSP settings ?
We also need to check audio settings of the zone you are playing to - Open Settings > Go to Audio tab > Open Device Setup screen for a zone you are playing to and take screenshots of all tabs there.
