After the new upgrade, my DSD files are not playing through my PS Audio DirectStream DAC. I have the Matrix X-SPDIF 2 connected using i2s. Through the Roon app, I set the Matrix to play DSD over DoP. it no longer works. Have to convert DSD to PCM. HELP
What DAC is it connected to ? IIRC it needs to be capable of DSD512 to accommodate DSD256 via DoP. Also you may want to review the led light colour of the Matrix to the manual. No light means no connection.
