I run on a [Intel NUC mini PC kit NUC 7i5BNK Core i5, ]I assembled this in July 2018.
It is connected via Ethernet to my QNAP hard drives and I use Node 2.1 as a music server also Ethernet connected.
I primarily access Roon from a 2019 Dell XPS.
My pathway is ROON to Node 2i to Audio Note DAC 2.1 to Preamp to amp to speakers
I just inserted my new Audio Note DAC into my system as described above.
I’m using a digital cable out from the Node to the DAC.
But I get no sound. I know the DAC works.
The Node 2i also feeds a sub and that is working.
I appreciate any suggestions to sort this out.
