I need some help with a problem I’m experiencing trying to authorise Roon to use my Tidal account. First the details:
Core Machine: Is a Dell Latitude running Windows 10 with these specs Intel Core i3 @ 1.70 GHz + 8GB of ram + 64-bit. The Roon Build is Version 1.7 (build 667) stable 64-bit).
The laptop is connected to my home network via wireless - the router is a TP Link Archer C20.
As an end point, I use a SOtM SMS-200 connected to the router via CAT5 cable and connected to my DAC via USB.
Now, my issue. After successfully configuring Roon and linking it to my Tidal account, it suddenly stopped picking up Tidal. Attempts to log in to Tidal have been unsuccessful. Roon prompts me to login, opens a browser window, where I successfully authenticate. However, this action doesn’t seem to be registering on Roon which continues to give me the message “You aren’t currently signed into TIDAL”. I have tried to log in numerous times with the same result.
Hi there. Thanks for your responses and follow-up questions. After further exploration I discovered it was a firewall issue. I had to completely disable Kaspersky, my anti-virus software, to resolve the issue. This is not ideal and I hope to find a solution that ensures reasonable protection for my PC while not interfering with the functioning of Roon. Anyone have experience of Kaspersky who could advice?
