Roon Rock Ver 1.7 (build 571) stable
PC Ver 1.7 (Build 610) stable 64bit (W10)
Ropieee Ver 1.7 (build 571) stable
All connection over ethernet , 1g, Switches Ubquiti
Sound via Roon Bridge into DAC / AMP
PC via DAC to headphones
Trying to install update onto Core, update shows to install and when you click Here to Install it fails with
“There was an error checking for an update”
Power cycled all devices, Roon is working, but will not update core
thank you all for your help on the above
