Roon Core runs on Microsoft Windows 11, Intel Core i9 12900K 3.2 GHz, 64GB DDR5
Modem from ISP
Ubiquiti EdgeRouter ER-4
Ubiquiti EdgeSwitch ES-24-250W
Mission LX Connect Wifi and Bluetooth
900 FLAC rip CD, 700 rip LP FLAC
Hello,
I’m having trouble using Roon from my Android phone and Apple Ipad.
From my Windows 10 computer it works fine.
I have also tested using WiFi from this computer and it works well.
I have installed Roon Core on another Windows 11 computer.
On my phone and iPad, Roon finds my Roon Core.
But then it can not connect to Roon Core.
I listen with Mission LX Connect which is Roon adapted.
I am very grateful for all the tips that can solve this.
Sincerely, Fredrik
Since you are using a Windows PC, I would verify that both Roon.exe and RAATServer.exe have been added as exceptions to your Windows firewall.
You can use these instructions to add the exceptions and the executables themselves would be located in your Database Location/Application folder path.
I would also add these exceptions to any Antivirus or other Firewall blocking applications you may have and ensure that you connected to your network via a Private network, not a Public one, see this guide for more information.
