Hello.
I have problems installing roon sever in Proxmox.
I have an Intel NUC (NUC11TNBi7), 32GB RAM
Welcome to the Roon Optimized Core Kit Setup
Would you like to:
- Install Roon Optimized Core Kit on this device?
- Recover a previous install of Roon Optimized Core Kit on this device?
Please type a number (1—2) and hit ENTER >1
Choose Install Disk
- 107GB, QEHU HARDDISK
On which disk would you like to install?
Please type a number (1—1) and hit ENTER > 1
Roon Optimized Core Kit is meant to be installed on an SSD, and not a spinning disk.
If you do not have a SSD, we strongly recommend you turn off this machine and go get one.
If you have one, make sure you are installing to to the SSD.
NOTE: Installing to this disk will permanently erase its existing contents and can not be undone.
Are you sure you want to install on this disk? (please confirm it is an SSD)
107GB, QEMU HARDDISK
Please type Y or N and hit ENTER > Y
Preparing Disk
Install RoonOS
Setting up RoonOS for first use
I get several different error message whe i do this (tar: bunzip error —5, tar : invalid tar header checksum or tar: short read etc)
ERROR: Failed to install RoonServer
There was a critical failure during installation.
Please press ENTER to reboot and try again, or contact support at
https : //connunity.roonlabs.corn/
Please note the above ERROR message and your hardware configuration
when contacting support .
HIT ENTER TO REBOOT
Very grateful for help installing Roon server on my NUC
My list on how I do the install
Balena Etcher file: roonbox-linuxx64-nuc4-usb-factoryreset.img.gz
Datacenter->pve->crate VM->
GENERAL: VM ID: 103, Name: roon server
OS: Do not use any media->Yes
SYSTEM: Machine: q35-> BIOS: OVMF (UEFI)-> EFI Storage: local-lvm
DISKS: scsi0 trash-> ADD: SATA-> DISCARD: Yes->DISK SIZE(GIB): 100->SDD emulation: Yes
CPU: Cores: 2
MEMORY: Memory(MIB): 8096
NETWORK: Model: Intel E1000
CONFIRM: Finish
I install a keyboard and USB stick with installation ISO
103 (roon server)->Hardware->Add->USB Device->Use USB Vendor/Device ID->Keycron keyboard
->USB drive
103 (roon erver)->Console->Start now->Esc->this enters the BIOS
Device manager → Secure Boot Configuration → Attempt Secure Boot NO-> F10 ->Y->esc->esc->Reset->Esc->I have problems installing roon sever in Proxmox.
Would you like to:
Choose Install Disk
Preparing Disk
Install RoonOS
HIT ENTER TO REBOOT
CPU: Cores: 2
CONFIRM: Finish
->USB drive
103 (roon server)->Console->Start now->Esc->this enters the BIOS->Device manager → Secure Boot Configuration → Attempt Secure Boot NO-> F10 ->Y->esc->esc->Reset->Esc->this enters the BIOS->Boot Manager->UEFI Kingston DataTraveler->Enter
