WIFI
Chromecast
I just bought the paid version of Roon as it seems to me an excellent tool for my hobby of listening music. Everything works fine except it doesn’t connect properly with my Chromecast devices (Chromecast Audio and Chromecast TV).
However, Chromecast does work very well in my Qobuz application or from my smartphone. I have tried shutdown, boot, etc. and I can’t find any solution. This is really a problem for me. I have not found the solution in your support community.
Hi Tom, when I installed Room I already had my Chromecast devices configured in Google Home. These devices appeared in my Roon application, the problem is that, when I want to listen to music through them, they take time to respond or simply don’t work, when they do, they only activate for a few seconds and dropout. I do not understand what happens since they work correctly with other applications like Qobuz. I have checked the settings of Google Home and everything seems correct but I still have the same problems.
No, my wifi is simple, never had problems. Maybe this helps: I found that Chromecast devices work well when, using Roon, I listen to radio stations (via My Live Radio), however they don’t work when I want to listen to my Qobuz music.
Roon can be picky with WiFi. Things like range extenders often cause problems…
Simple things first…
Are the Qobuz streams high resolution (ie big!)?
What happens if you play local files?
Are you able to try a wired ethernet cable from router to MacBook?
I have tried to lower the quality in Qobuz and it works better so it seems that was the problem. As I do not have the Ethernet adapter for the MacBook (I have ordered it and it will arrive soon), I have changed the band of the Wi-Fi of the MacBook to 5G and also it improves the system.
I think that in a few days I will have everything resolved and it will work correctly.
Thank you very much for answering me soon and helping me to solve the problem, I am really enjoying Roon.
All Roon core, endpoint and remote devices do need to be on the same subnet; but in most home networks that is true by default, whether wired or wireless. Are you using a separate WiFi hub/range extender/access point/etc that your remotes connect to?
Yes @AndyR I’m using a WiFi hub Tenda Mesh System in charge of all the WiFi devices at Home (3 separate Cubes) and One of them is wirely connected to the Router it is called the gateway and gives IP to the WiFi devices
All other devices PC’s TV’s are wirely connected to the Router
In fact 2 Networks but connected one each other
It’s likely the ‘two networks’ that is the problem; if you want to change it I think you need to reconfigure so that all devices get their IP address from the same DHCP service. Possibly a bit of physical replugging if that’s practicable (I don’t know if you have any intermediate ethernet switches) or by config settings in router or mesh system.
Yes that’s what I want to do
Only 1 Gateway and only 1 DHCP serveThe Router
That’s what I’m planning to do
But for the moment I’ve found a compromise that feet me , and I’ll make Tests and experimentations later
Regards @AndyR
Hi again Andy! Today the Ethernet adapter I bought has arrived, I have connected the MacBook directly to the wired Ethernet network and I am very happy to tell you that, although it had already improved connecting it to the 5G wifi band, now everything works much better…
