NUC on ethernet, Bluesound on WiFi (TPLink Deco M5)
BlueSound Node 3i - normally on Coax but now testing USB because amp wil be replaced by Hifiman EF400 (USB only)
Auralic Altair G1 ethernet
Windows laptop (ethernet)
PopOS! laptop (wifi) Bridge mode via iPad or iPhone
Music on Qobuz and Synology (ethernet)
? 1650 Albums
When playing music through USB on Bluesound Node 3i to SPL Phonitor SE static noice/dropouts occur.
Playing the same route without Roon does not!
They’ve acknowledged the problem with using USB with Roon. I’m hoping the fix will be soon. Until then, using anything other than USB could work around this issue for you.
