Roon 1.7 (build 505?)
iPad pro with OS 13.2.3.
Roon does not start on the iPad. Roon screen pops up just to disappear again.
Try removing it (delete) and reinstall from App Store.
Hi @Thomas_Boeckel,
I would second @wizardofoz’s suggestion, can you try reinstalling the Roon app and let us know if that helps?
Thanks for the tipp. Looks like it works now.
