Problems with qobuz
Roon stops playing qobuz after I randomly played four titles. I restarted the system several times, after I got a new SSD, i also reinstalled Roon and qobuz. Same problem afterwards.
Here pictures of system and problem in Roon.
Network is ok, restarted everything several times, speedtest shows 103 Mb/s and the computer has a wired connection. Roon is installed on the iMac.
No problem with the Qobuz desktop app. And no problems with BluOS players in my system with Qobuz (without using roon).
Thx for helping
What is your internal network make and model.
It’s a Telekom Speedport. All my equipment is wired through ethernet cat 6.
A post was split to a new topic: Roon works with Tidal but not with Qobuz
A post was split to a new topic: Qobuz plays but keeps on stopping
5 posts were split to a new topic: Problem playing Qobuz content in Roon
A post was split to a new topic: Random stops playing music from Qobuz
Hello @Christoph_Hegerl, and thanks for your report! Are you seeing this issue with local content or playback to system output?
Not with local content (another problem that the Apple Music playlist are not existent after resetting the system)
Only with Qobuz streaming.
Hello @Christoph_Hegerl, any issues playing to system output of your mac? Have you tried temporarily lowering your streaming quality under Settings>Services to see if you have this same issue?
