Problems with roon display
Hi
I hope this is a simple fix
I’m running roon core on an old pc and have just connected a google nest hub as a display. When I press play the screen on the nest hub switches to roon and displays the track playing. Perfect. However, after 90 seconds the nest hub changes the display to show the google clock or google photo slide show. Roon is still being cast to the nest hub but you have to keep scroll through the hub to find roon and then after 90 seconds it switches the display on the hub again. Stopping a music track and starting again does nothing. The only way to get hub to auto switch to roon again, is to go into the google home app, click on the nest hub and click stop casting. Then, next time you select play on roon, the nest hub will switch to roon display, but again for only for 90 seconds.
Can you help please ??
Matt
2 posts were merged into an existing topic: Google Nest Hub as a Roon Display
