Roon 1.7 Build 555 running on SonicTransporter running 2.7
cat 8 ethernet connected to ExaSound PlayPoint
ExaSound PlayPoint connected by usb cable ExaSound e38 multichannel dac into Placette passive multichannel preamp (custom made) a 5.1 surround sound system of B&W 801s (matrix) with Custom North Creek crossovers. I have removed the base equalizers that were part of the original B&W 801s because running the line level signal though them diminishes the sound slightly. I have done all base management to correct for this is the analog domain with a subwoofer.
This is a question not a technical problem I am trying to solve. It is a request for technical information.
I have build my entire system around doing as little digital processing as possible. Most of my files are DSD 64 files and any processing for bass management or room EQ diminishes the sound quality.
With Roon’s Procedural EQ I am starting to make and exception by routing signals from the speakers into the subwoofer. All speaker are full range, so the sub is used only for the very bottom end. When I turn on the EQ with only the mix running and only routing full signal to the subwoofers, the Delta Signal Modulator is engaged. I understand the technicalities of why this is so–to mix various source signals and the reconvert them to DSD. My question is this: Does the DSD mess with the digital signal that is going direct to the speakers (Right to Right or Left to Left, for example)? Are these signals left unaltered? Are only the Digital signals that are going to the Sub modulated (Right to sub, Left to sub, etc.)? I can live with modulation in the signal going to the Sub, but do not want to have modulation of the signals going to the other speakers. I look forward to learning if the mix I am using leaves the main and surround speaker signals unaltered.
