New user here, still on trial period…
Roon Nucleus Rev A connected to home LAN via Ethernet CAT6
Have 2 endpoints:
a - BlueSound Node 2i via wifi (both as streamer using its digital out, as well as as streamer/DAC)
b - Weiss DAC501 which works as a Roon endpoint as well - using its Ethernet connection
Issue - Quboz will load all content, even high res feeds (24/96, 24/192) just fine to the Node 2i over wifi… but when using the Weiss as the endpoint (via ethernet), Quboz fails to feed through, constantly skips, jumps tracks, sometimes stops altogether. The control screen will then say ‘Qobuz loading slowly, likely network problem, check your connections’…
Why is this? The Weiss is a superior machine sonically and I have made sure all software on it and on the Core are current, yet Qobuz content just won’t feed through correctly!
My internet signal is coming into the house via an Xfinity cable modem, LAN and wifi router – Xfinity’s XB7 CGM4331COM (Technicolor) modem Gateway
Very frustrating, as Qobuz hi-res is to me the sonically superior streamed music feed (better than Tidal, Deezer and of course, Spotify and Amazon).
If I can’t get this to work I may need to just go back to Blu Os, which, while not as nice as Roon, works reliably in delivering the music…
Filled out a service problem ticket last Friday but zero response from Roon as yet.
