Questyle M18i Max for my iPhone with interference
I recently purchased a Questyle M18i Max for my iPhone SE 2022, which requires the use of a Lightning-to-USB-C OTG cable. I have one, and it’s about 10 cm long. Because both devices end up being positioned very close to each other, I frequently experience interference. According to an analyse from AI: this is caused by electromagnetic interference (EMI) from the iPhone’s antenna affecting the sensitive chip in the Questyle M18i Max—specifically when the phone has to transmit at high power in challenging signal conditions. In my apartment, I noticed the interference only when I was in the storage room downstairs; interestingly, the Tanchjim Space didn’t have this issue at all. I also encounter interference on the train when streaming via Roon Arc or Qobuz but not with the Tanchjim. When I used a longer cable combined with an OTG adapter, allowing me to keep the two devices further apart, the interference disappeared.
I searched online for a longer cable so I wouldn’t have to use that clunky (white Apple) adapter, but I had no luck finding one. While there are cheaper, compact OTG adapters available that allow you to connect a standard USB-C cable, perhaps there are simpler solutions?
Has anyone else experienced this type of interference, and what steps did you take to resolve it?
Ultimately, I ended up using an OTG adapter connected to a USB-Lightning-to-C cable. It’s not very elegant—and it’s quite vulnerable, as a long piece now sticks out from my mobile phone—but the interference issues are gone. Apparently, this mobile DAC is highly sensitive to radiation from the iPhone while streaming music via ARC. I was hoping to find a Lightning-to-C OTG cable, but none seem to exist that are longer than 20 cm. If anyone knows where to find such a cable, I’d love to hear about it.
