Random loss of connection and other problems
Hi @Andrew_McMurdo,
Can you confirm that the folder you’re trying to access has been properly shared over the network? You can see our documentation on this here.
Thank you Dylan. Problem solved with aid of the sharing documentation you sent.
Found music files had been deleted from MacBook so tried “office” macmini again and I had been omitting the “.local” part of the host name. Connected straight away and playing with no interruptions so far.
One point, the preferences/share/options box showed admin name rather than username and that did not work but username did.
Confusing in that in the past I have connected without adding the “.local”.
I will let you know in due course if the interruptions start again or if all continues OK. Many thanks.
