I always wondered exactly what AQWOX changed apart from the housing compared to the €30ish switch it’s based apart from the branded housing…
As mentioned before, if you pull the cable between your endpoint and your switch, do you hear a sound improvement before the it stops playing before it stops when the app buffer is empty?
If so do think electronic gremlins affected the sound are also buffered by the application or the networks layer underneath?
Yikes. Basically a $500 switch setup???
My $30 Linksys 8-port GigaBit switch and $10 Cat 6 cables were expensive enough…
I have an Asus RT-AC68U 4 port router.If I get a 5 port unmanaged switch, will I be able to use both for ethernet connections?
Thanks for any help…
Yes you can use both of them for your network.
