Remote audio devices not discovered
i7-4790 8-cores 3.6GHz 12GB RAM
Ubuntu 20.04.3 LTS 64-bit
Unifi DreamMachine (Network 6.5.55 / System 1.10.4) using Ethernet
  • iPad-Pro 9.7
  • 6 Sonos devices (4 roon-tested)
  • Devialet 220Pro (roon-ready)
  • Windows 11-Home PC (Ryzen 9 3900XT, 32GB RAM) with 2 audio devices connected via USB: AudioQuest DragonFly Cobalt & Aune X8 Magic Dac
I installed RoonServer on my Ubuntu server.
Once done, I’m able to connect to RoonServer from my iPad, login, add tracks and play some music from RoonServer to the iPad.
All Sonos devices are also discovered.
However, when I install Roon on my Windows 11 PC, the 2 connected devices (DragonFly and Aune X8) are not discovered by the remote RoonServer.
I have done some investigations but nothing.
RoonServer and Roon running on Win11 PC are the same version: 1.8 (build 882)
They run on the same subnet
  • RoonServer:
  • Roon on PC
Roon running on PC successfully discovered the 2 connected USB devices
but the RoonServer never receives the ā€œbroadcastā€ of this discovery so the 2 devices don’t appear in the list of available audio renderers.
The only issue that I see is in the RAAT log on the Windows11 PC
Thanks for your help
Good job with your investigation. I suspect this is a firewall issue. Perhaps try disabling the Windows firewall and then restart Roon.
Also, why are you running Roon Server on your Windows 11 PC? You only need one copy of Roon Server running on your network. If you have a DAC connected to your Windows 11 PC that you want to use as an Output, I’d suggest uninstalling Roon Server and replacing it with Roon Bridge.
You can run Roon Bridge alongside the Roon desktop UI (functioning as a Control), but don’t mix Roon Server and Roon Bridge on the same machine. That’s like crossing the streams in Ghostbusters. Not pretty. :slight_smile:
I hope this helps!
Thanks.
I have uninstalled Roon on my Windows PC, rebooted, installed RoonBridge and it did not help.
All my FW are disabled,
  • on Windows PC
  • and on the Linux machine of RoonServer
I suspect an issue with broadcasting of devices from my RoonBridge Windows11 to the RoonServer running on Ubuntu.
I have re-installed from scratch RoonBridge on Windows11, everything seems normal at startup.
No error on logs (RAAT and Bridge) and the USB connected devices are detected in RAAT and broadcasted OK over the network at 13:59:38 on port 9200:
12/21 13:59:38 Trace: [raatmanager] starting
12/21 13:59:38 Trace: [raatmanager/windows] FOUND type=wasapi id={0.0.0.00000000}.{182d1d44-286b-4f62-9dfe-7710971a1388} usb_id=
12/21 13:59:38 Trace: [raatmanager/windows]       name=NVIDIA High Definition Audio   output_name=PHL 274E5
12/21 13:59:38 Trace: [raatmanager/windows] FOUND type=wasapi id={0.0.0.00000000}.{1bdb27a5-998b-4bce-ab38-45696f9a82bb} usb_id=
12/21 13:59:38 Trace: [raatmanager/windows]       name=Devialet AIR                   output_name=Speakers
12/21 13:59:38 Trace: [raatmanager/windows] FOUND type=wasapi id={0.0.0.00000000}.{82709390-3500-486b-9824-d55b66ebeb6c} usb_id=21b4:0085
12/21 13:59:38 Trace: [raatmanager/windows]       name=AudioQuest DragonFly Cobalt v1.0 output_name=Speakers
12/21 13:59:38 Trace: [raatmanager/windows] FOUND type=wasapi id={0.0.0.00000000}.{f07a2b6a-faa4-4e5f-9d04-b5b604006a5c} usb_id=
12/21 13:59:38 Trace: [raatmanager/windows]       name=High Definition Audio Device   output_name=Digital Audio (S/PDIF)
12/21 13:59:38 Trace: [raatmanager/windows] FOUND type=asio   id={F0918C00-B056-4087-88DF-817F245868B2} usb_id=
12/21 13:59:38 Trace: [raatmanager/windows]       name=ASIO MADIface USB              output_name=
12/21 13:59:38 Trace: [raatmanager/windows] FOUND type=asio   id={FBD8E51C-6638-4867-A3C9-D0C099CC51E0} usb_id=
12/21 13:59:38 Trace: [raatmanager/windows]       name=JRiver Media Center 20         output_name=
12/21 13:59:38 Trace: [raatmanager] initialized
12/21 13:59:38 Info: [RAATServer] running RAAT__manager
12/21 13:59:38 Trace: [raatmanager] starting discovery
12/21 13:59:38 Trace: [discovery] starting
12/21 13:59:38 Info: [discovery] [iface:Ethernet:192.168.1.21] multicast recv socket is bound to 0.0.0.0:9003
12/21 13:59:38 Info: [discovery] [iface:Ethernet:192.168.1.21] multicast send socket is bound to 0.0.0.0:65200
12/21 13:59:38 Info: [discovery] [iface:Loopback Pseudo-Interface 1:127.0.0.1] multicast recv socket is bound to 0.0.0.0:9003
12/21 13:59:38 Info: [discovery] [iface:Loopback Pseudo-Interface 1:127.0.0.1] multicast send socket is bound to 0.0.0.0:65201
12/21 13:59:38 Info: [discovery] unicast socket is bound to 0.0.0.0:9003
12/21 13:59:38 Trace: [raatmanager] starting server
12/21 13:59:38 Info: [jsonserver] listening on port 9200
12/21 13:59:38 Trace: [raatmanager] announcing
12/21 13:59:38 Debug: [discovery] broadcast op is complete
On the RoonServer side,
nothing happens at that time on RoonServer RAAT:
12/21 13:59:06 Trace: [discovery] starting
12/21 13:59:06 Info: [discovery] [iface:lo:127.0.0.1] multicast recv socket is bound to 0.0.0.0:9003
12/21 13:59:06 Info: [discovery] [iface:lo:127.0.0.1] multicast send socket is bound to 0.0.0.0:57575
12/21 13:59:06 Info: [discovery] [iface:enp2s0:192.168.1.22] multicast recv socket is bound to 0.0.0.0:9003
12/21 13:59:06 Info: [discovery] [iface:enp2s0:192.168.1.22] multicast send socket is bound to 0.0.0.0:36451
12/21 13:59:06 Info: [discovery] unicast socket is bound to 0.0.0.0:9003
12/21 13:59:06 Trace: [raatmanager] announcing
12/21 13:59:06 Debug: [discovery] broadcast op is complete
12/21 13:59:12 Debug: [easyhttp] [5] POST to https://discovery.roonlabs.net/1/register returned after 366 ms, status code: 200
12/21 13:59:12 Trace: [inetdiscovery] registered 1 devices, 1 services
12/21 14:06:33 Trace: [jsonserver] [127.0.0.1:56490] accepted connection
nor RoonServer itself:
12/21 13:59:06 Trace: [roonapi] network reachability changed. Kicking off discovery cycle
12/21 13:59:07 Trace: Successful POST response from https://push.roonlabs.com/push/1/connect
12/21 13:59:07 Trace: [push] connecting to 35.196.114.77:9204
12/21 13:59:07 Trace: [push] connected
12/21 13:59:07 Debug: [easyhttp] [45] POST to https://discovery.roonlabs.net/1/query returned after 474 ms, status code: 200
12/21 13:59:07 Debug: [easyhttp] [47] GET to https://internetradio.roonlabs.net/2/api/location?format=msgpack& returned after 499 ms, status code: 200
12/21 13:59:07 Debug: [easyhttp] [46] GET to https://internetradio.roonlabs.net/2/api/location?format=msgpack& returned after 500 ms, status code: 200
12/21 13:59:07 Trace: [radio/library] got location BE
12/21 13:59:08 Trace: [server] network reachability changed. Kicking off discovery cycle
12/21 13:59:12 Debug: [easyhttp] [48] POST to https://discovery.roonlabs.net/1/register returned after 456 ms, status code: 200
12/21 13:59:12 Trace: [inetdiscovery] registered 1 devices, 4 services
12/21 13:59:16 Info: [stats] 27350mb Virtual, 1147mb Physical, 414mb Managed, 261 Handles, 102 Threads
12/21 13:59:31 Info: [stats] 27262mb Virtual, 1147mb Physical, 415mb Managed, 261 Handles, 87 Threads
12/21 13:59:46 Info: [stats] 27366mb Virtual, 1147mb Physical, 416mb Managed, 261 Handles, 104 Threads
12/21 14:00:01 Info: [stats] 27294mb Virtual, 1148mb Physical, 416mb Managed, 261 Handles, 91 Threads
I have checked the TCP connections on the RoonBridge Windows11 PC, where everything seems ā€œOKā€.
There is (only) 1 TCP connection (ESTABLISHED) to the RoonServer with port 9332
TCP 192.168.1.21:50938 PC-MULTIMEDIA:9332 ESTABLISHED [Roon.exe]
which seems to correspond to the same port on RoonServer:
Info: [broker/distributed] Remoting server listening on port 9332
Full TCP list of RoonBridge:
  TCP    127.0.0.1:9004         PC-HOME8:51118         ESTABLISHED [RAATServer.exe]
  TCP    127.0.0.1:9200         PC-HOME8:50954         ESTABLISHED [RAATServer.exe]
  TCP    127.0.0.1:50954        PC-HOME8:9200          ESTABLISHED [Roon.exe]
  TCP    127.0.0.1:50986        PC-HOME8:50987         ESTABLISHED [RAATServer.exe]
  TCP    127.0.0.1:50987        PC-HOME8:50986         ESTABLISHED [Roon.exe]
  TCP    127.0.0.1:50988        PC-HOME8:51204         ESTABLISHED [RAATServer.exe]
  TCP    127.0.0.1:51118        PC-HOME8:9004          ESTABLISHED [Roon.exe]
  TCP    127.0.0.1:51126        PC-HOME8:51127         ESTABLISHED [RAATServer.exe]
  TCP    127.0.0.1:51127        PC-HOME8:51126         ESTABLISHED [Roon.exe]
  TCP    127.0.0.1:51204        PC-HOME8:50988         ESTABLISHED [Roon.exe]
  TCP    192.168.1.21:50975     Expert220Pro:36991  ESTABLISHED [Roon.exe]
  TCP    192.168.1.21:51272     151.101.2.142:http     ESTABLISHED [Roon.exe]
  TCP    192.168.1.21:51273     158:https              ESTABLISHED  [Roon.exe]
  TCP    192.168.1.21:51275     158:https              ESTABLISHED  [Roon.exe]
  TCP    192.168.1.21:51277     31:https               ESTABLISHED [Roon.exe]
  TCP    192.168.1.21:51278     165:9204               ESTABLISHED  [Roon.exe]
ANd here’s the list of UDP connections on RoonBridge:
  UDP    0.0.0.0:1900           *:*                     [Roon.exe]
  UDP    0.0.0.0:3702           *:*                     [Roon.exe]
  UDP    0.0.0.0:5353           *:*                     [Roon.exe]
  UDP    0.0.0.0:9001           *:*                     [Roon.exe]
  UDP    0.0.0.0:9003           *:*                     [Roon.exe]
  UDP    0.0.0.0:9003           *:*                     [RAATServer.exe]
  UDP    0.0.0.0:45454          *:*                     [Roon.exe]
  UDP    0.0.0.0:52987          *:*                     [RAATServer.exe]
  UDP    0.0.0.0:52988          *:*                     [Roon.exe]
  UDP    0.0.0.0:53509          *:*                     [Roon.exe]
  UDP    0.0.0.0:59746          *:*                     [Roon.exe]
  UDP    0.0.0.0:59747          *:*                     [Roon.exe]
  UDP    0.0.0.0:59749          *:*                     [Roon.exe]
  UDP    0.0.0.0:59750          *:*                     [Roon.exe]
  UDP    0.0.0.0:59751          *:*                     [Roon.exe]
  UDP    0.0.0.0:59752          *:*                     [Roon.exe]
  UDP    0.0.0.0:59753          *:*                     [Roon.exe]
  UDP    0.0.0.0:59754          *:*                     [Roon.exe]
  UDP    0.0.0.0:59755          *:*                     [RAATServer.exe]
  UDP    0.0.0.0:59756          *:*                     [Roon.exe]
  UDP    0.0.0.0:63851          *:*                     [Roon.exe]
  UDP    0.0.0.0:63852          *:*                     [RAATServer.exe]
  UDP    0.0.0.0:63853          *:*                     [RAATServer.exe]
  UDP    0.0.0.0:63854          *:*                     [RAATServer.exe]
  UDP    192.168.1.21:1900      *:*                     [Roon.exe]
So in short, everything seems ok for my untrained eyes but still I cannot get the USB devices remotely connected.
Any clue? Thanks
I tried something else today.
I could get my hands on a new Windows10 PC, on which I installed RoonServer in place of the RoonServer that was running on Ubuntu 20.
And everything is running perfectly: The Win10 RoonServer can see the USB audio devices attached on my Win11 PC :+1:
Which means that:
  • There are no problems on the Win10 PC: Roon and Windows firewall :white_check_mark:
  • The are no problems on my network (router, LAN setup, etc.) :white_check_mark:
  • The problem is somewhere on the RoonServer installed on Ubuntu20, but where ? :confused:
Still investigating …
As I couldn’t figure out the source of the problem, I went for a ā€˜Reset this PC’ aggressive plan on my Windows11 PC.
And it fixed the issue :ok_hand:
I don’t know what was wrong on this PC, maybe after I upgraded from Win10 to Win11, who knows…
Good thing is I can enjoy the full Roon experience in my house now ! :notes:
