No matter what I do, the iPad or MacBook Air I want to use as a remote can’t find my Roon library on my main iMac. I’ve checked all the things the prompt tells you to do, including inputting an IP address.
Hi Allen,
Shifted your post here to Support in case it needs dev attention. Could you firstly check through these these common issues. If nothing there helps then we’ll notify some Support devs.
