Streamer is a Pink Faun Audio Streamer is running Roon Version 1.7
The Mac Mini 2018 is running Roon Version 1.7
Kef Egg is out of the box.
The Pink Faun Audio streamer is connected to Router FritzBox 7490 per LAN
The Mac mini is connected to Wifi
Kef Egg is connected through the EIZO EV2451 monitor hub via USB, hub is connected to Mac mini
The problem is that I cannot use the remote for controlling the volume. I can play/pause but I cannot control the volume. I can control the volume however in Apple Music.
I have selected under Volume Control the option Device Volume as this was working under Windows. Did I forget something? Or do I need to change some settings?
By switching the USB connector from the HUBof the EIZO directly to the Mac mini 2018 does not solve the issue. So to answer your question the behavior is the same.
Thanks for checking. The next step here is to see if the Roon logs show these actions occuring, can I please ask that you reproduce the issue (try to use the volume control from the remote) and let me know the exact local time + date + track you tried to reproduce the issue with? Once I have the timestamp, I can enable diagnostics mode for your account.
Happy Holidays and thank you for the timestamp! I tried to enable diagnostics mode for your account and what this should have done is deliver a log set to us, but unfortunately I am not seeing the logs come in. Can you please use these instructions to send me a copy of your Mac Roon logs?
