Sonic transport i5 Version 1.7, 511 stable
Ethernet to BT home hub, 64 bit iPad remote. Reinstalled and rebooted.
USB direct storage HDD.
OPPO 205.4K player.
After upgrae I can’t get Roon to open. The iPad finds it but it says " initialising".
Also I was trying to add a wifi speaker to the system (and may have introduced another network?). I used my MacBook pro as a roon bridge with a Monitor Audio Airstream S200 speaker. It worked well initially.
Log
12/22 13:49:47 Info: Starting RoonServer v1.7 (build 511) stable on linuxx64
12/22 13:49:47 Trace: Checking if we are already running
12/22 13:49:47 Warn: get lock file path: /tmp/.rnsems0-roon
12/22 13:49:47 Trace: Nope, we are the only one running
12/22 13:49:47 Info: Is 64 bit? True
12/22 13:49:47 Info: Command Line Argument: -watchdogport=35625
12/22 13:49:47 Trace: [childprocess] using .NET child process
12/22 13:49:47 Trace: [realtime] fetching time from NTP server
12/22 13:49:47 Warn: [realtime] failed to get time: Could not resolve host 'pool.ntp.org'
12/22 13:49:47 Info: [broker] starting a0270b5c-59c5-4b54-b63d-830ce68b21cc
12/22 13:49:47 Trace: [httpcache] loaded 1536 cache entries from /var/roon/RoonServer/Cache/httpcache_2.db, current: 127mb / 128mb
12/22 13:49:47 Debug: [broker/filebrowser/nassharemaker] rebuildsymlinks
12/22 13:49:48 Info: [stats] 1227mb Virtual, 49mb Physical, 16mb Managed, 0 Handles, 17 Threads
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] initial listing found drive mounted at /
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] initial listing found drive mounted at /boot
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] initial listing found drive mounted at /storage
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] skipping /storage because it is not a removable drive (mountline: /dev/sda5 /storage ext4 rw,relatime,data=ordered 0 0), also the drive's /sys/block/sda path contains no '/usb': ../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0/block/sda
12/22 13:49:51 Info: [broker/locations] adding storage location: Internet:Name=Internet Media:Id=e268f098-04c4-4e65-af3f-38ba3c3fcecb
12/22 13:49:51 Info: [broker/locations] media availability: Internet:Name=Internet Media:Id=e268f098-04c4-4e65-af3f-38ba3c3fcecb is online
12/22 13:49:51 Info: [broker/locations] adding storage location: MetadataService:Name=Metadata Service:Id=13769258-b70b-4243-b1d6-bd46e8257ba8
12/22 13:49:51 Info: [broker/locations] media availability: MetadataService:Name=Metadata Service:Id=13769258-b70b-4243-b1d6-bd46e8257ba8 is online
12/22 13:49:51 Info: [broker/locations] adding storage location: Offline:Name=Offline:Id=f1e4b43f-f643-47ba-b875-fd93b32a6006
12/22 13:49:51 Debug: [broker/locations/migration] start, propname: loc_29bdcae6b5fdd66627bfa1f6afceabac
12/22 13:49:51 Debug: [broker/locations] Migrating UUID based storage location, id: loc_29bdcae6b5fdd66627bfa1f6afceabac, version: 2
12/22 13:49:51 Debug: [broker/locations/migration] start, propname: loc_9cf1962deaf34c3e836f45aed7bf850e
12/22 13:49:51 Debug: [broker/locations] Migrating UUID based storage location, id: loc_9cf1962deaf34c3e836f45aed7bf850e, version: 2
12/22 13:49:51 Debug: [broker/locations/migration] start, propname: location_automounts
12/22 13:49:51 Debug: [broker/locations] load pre 1.3 automounts, strlist:
12/22 13:49:51 Warn: [linuxmount/pinfo] coudn't ascertain disk block device from sysfs
12/22 13:49:51 Trace: [storage] [directory] directorystorage init, location(/storage, dirwatcher is available: True)
12/22 13:49:51 Trace: [storage] [directory] init just before reorg delete thread, path: /storage
12/22 13:49:51 Info: [broker/locations] storage location backend created and attached (DefaultMusicFolder:Name=Music Folder:Id=29bdcae6-b5fd-d666-27bf-a1f6afceabac)
12/22 13:49:51 Trace: [storage] [directory] temp directory cleared, path: /storage/.tmp
12/22 13:49:51 Info: [broker/locations] adding storage location: DefaultMusicFolder:Name=Music Folder:Id=29bdcae6-b5fd-d666-27bf-a1f6afceabac
12/22 13:49:51 Info: [broker/locations] media availability: DefaultMusicFolder:Name=Music Folder:Id=29bdcae6-b5fd-d666-27bf-a1f6afceabac is online
12/22 13:49:51 Info: [broker/locations/directorystoragelocation] initializing FileBrowser.Entry: M B, WDC WD10EAVS-00D7B1 : /, drive availability is: False
12/22 13:49:51 Info: [broker/locations/directorystoragelocation] drive is not available so disposing resources (if they exist): FileBrowser.Entry: M B, WDC WD10EAVS-00D7B1 : /
12/22 13:49:51 Info: [broker/locations] storage location backend (Folder:Name=:Location=FileBrowser.Entry: M B, WDC WD10EAVS-00D7B1 : /:Id=9cf1962d-eaf3-4c3e-836f-45aed7bf850e) offline reason changed to: DriveNotReady
12/22 13:49:51 Info: [broker/locations/directorystoragelocation] we'd like to keep this volume mounted: mounted:/storage/usbdrive
12/22 13:49:51 Info: [broker/locations] created enabled location, FileBrowser.Entry: M B, WDC WD10EAVS-00D7B1 : /
12/22 13:49:51 Info: [broker/locations] adding storage location: Folder:Name=:Location=FileBrowser.Entry: M B, WDC WD10EAVS-00D7B1 : /:Id=9cf1962d-eaf3-4c3e-836f-45aed7bf850e
12/22 13:49:51 Debug: [broker/locations] write pre 1.3 automounts, strlist:
12/22 13:49:51 Info: [media] resolved oop decoder to /usr/bin/ffmpeg
12/22 13:49:51 Trace: [brokerserver] Enabling broker server
12/22 13:49:51 Info: [broker/distributed] HTTP server listening on port 9100
12/22 13:49:51 Trace: [broker/backups] initializing
12/22 13:49:51 Info: [broker] is licensed for userid e22cf65e-cbe6-4b89-bd32-71f876bfe968
12/22 13:49:51 Info: [clientdata] initializing with /var/roon/RoonServer/Database/Core/e22cf65ecbe64b89bd3271f876bfe968/clientdata.db
12/22 13:49:51 Trace: [broker/accounts] Data updated. AccountStatus=LoggedIn MachineStatus=Licensed UserId=e22cf65e-cbe6-4b89-bd32-71f876bfe968
12/22 13:49:51 Trace: [broker/accounts] [heartbeat] now=12/22/2019 1:49:52 PM nextauthrefresh=12/22/2019 1:44:52 PM nextmachineallocate=12/22/2019 1:54:52 PM
12/22 13:49:51 Trace: [broker/accounts] doing auth refresh, next=12/22/2019 1:44:52 PM
12/22 13:49:51 Trace: [broker/accounts] refreshing account info for email='clarkzian@hotmail.com' userid=e22cf65e-cbe6-4b89-bd32-71f876bfe968
12/22 13:49:51 Trace: [fiveaccountserver] POST https://accounts5.roonlabs.com/accounts/3/login
12/22 13:49:51 Trace: [fiveaccountserver] BODY token=18d02765-e755-4b4e-b45a-11c3c2089210
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /proc
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /dev
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/kernel/security
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /dev/shm
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /dev/pts
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /run
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/systemd
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/pstore
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/freezer
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/cpu,cpuacct
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/blkio
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/net_cls,net_prio
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/pids
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/perf_event
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/hugetlb
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/memory
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/devices
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/fs/cgroup/cpuset
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/kernel/config
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /proc/sys/fs/binfmt_misc
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /sys/kernel/debug
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /dev/hugepages
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /dev/mqueue
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /tmp
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /boot
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /storage
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /var/lib/nfs/rpc_pipefs
12/22 13:49:51 Debug: [volumewatcher] ev_VolumeChanged DidMount: /storage/usbdrive
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] initial listing found drive mounted at /storage/usbdrive
12/22 13:49:51 Warn: [linuxmount/pinfo] coudn't ascertain disk block device from proc
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] found newly mounted drive at /sys
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] skipping /sys because it is not a /dev/sd[0-9]* (mountline: sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0)
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] found newly mounted drive at /proc
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] found newly mounted drive at /dev
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] skipping /proc because it is not a /dev/sd[0-9]* (mountline: proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0)
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] skipping /dev because it is not a /dev/sd[0-9]* (mountline: devtmpfs /dev devtmpfs rw,nosuid,size=4030104k,nr_inodes=1007526,mode=755 0 0)
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] found newly mounted drive at /sys/kernel/security
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] skipping /sys/kernel/security because it is not a /dev/sd[0-9]* (mountline: securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0)
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] found newly mounted drive at /dev/shm
12/22 13:49:51 Debug: [broker/filebrowser/volumeattached] skipping /dev/shm because it is not a /dev/sd[0-9]* (mountline: tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0)
