Replaced 4GB with 8GB RAM on Nucleus: now, it won’t power up
In my Rev. A base Nucleus, I replaced the RAM as described with RAM recommended by one of the Roon principals in this forum. Now, it won’t power up. I’m sure I connected everything appropriately. Any thoughts before I tear it appart to check connections?
If there is nothing al all happening with the power on button then it seems it would have to be something between the power port on the device and the connection to the motherboard. Don’t know if that is a soldered or plug connection internally.
If its getting power you should see some indication, lights or error messages via HDMI to monitor or TV. But I’m sure you’re aware of that.
Id pull it apart, check the RAM is seated properly.
If it still fails put the old memory back and check it boots.
Memory compatibility possibly…
You nailed it Ged, thanks. Reinstalled old memory and new memory in second slot and it powered up. Appreciate the help.
