Core Machine ROCK Serial #408D5CA6426D
Ethernet 1Gb
LINN MAJIK DS Etherent connected. External USB Hard disk 4TB G drive formateed Ex FAT
Every thing was working fine, but In order to get the ripped CD into the usb drive I had to format it to ExFAT and doing it I did lost my setting and data base. Whe trying to reset in configuration of ROCK I do not get it.
Rock is connected to the ethernet. USB hard disk it is correctly connected. I am doing with remote roon in my mac correctly connected to ethernet.
The Message I read is "ROON DATA BASE AND SETTING not ready and whe resetting no answer. I have try as well to scan the previous IP I had. No response
