· Something else
I am using Roon on an old MacBook Pro 2014, running Mac OS 11.7.10, iPad. The streamer is Denafrips ARCE and dac is Topping DX9 15th Anniversary. The dac is just in dac-mode, output via XLR directly to power amp.. After the last ROON-upgrade the right channel is without sound. When I use the head-amp and play my AKG 701 phones via the 6,3 mm unbalanced connection the sound is normal. I have tried different dacs and streamers with the same result. I have also changed interconnects and I2S with the same result. The amp. is ok. I think the problem must be i software. Any suggestions?
See above
