Roon ROCK / NUC 8 i5 / OS Version 1.0 (build 219) stable / Roon Version 1.7 (build 571) stable
Network
Netgear Prosafe Plus / NUC connected wired Ethernet
PS Audio Nuwave DSD DAC connected USB
Trying to optimize connection between Roon and DAC. In setup for DAC, choosing Native gives a hiss, no music. Choosing DSD over PCM, which is how I think DAC handles DSD, give no sound at all. Choosing convert to PCM works, no DSD light when playing DSD files.
Any settings in DSP that would enhance playback of high quality local files, MQA or DSD streamed?
The DSD light come on. I believe 128 (2X) is the max the DAC will do.What settings should I have for Sample Rate Conversion Filter and Sample Rate Modulator (terms that are unknown to me).
Just wanted to add an update. The problem returned. I don’ t think I changed anything. So I reset the DAC and DSP in Roon to default settings and then everything worked fine.
I wanted to put this here in case anyone had a similar problem in the future.
