NUC7i3 running ROCK connected with HDMI to my Denon AVR-X4300H
iPad Pro as Roon Remote
My problem:
I do not hear a single tone coming out of my speakers. The files I am selecting thru Roon Remote on the iPad do work and play fine when streamed using my Sony BDP & Music Center (iOS app).
The signal path shows pink diamonds and the Denon sees a multi channel signal as input, but does not put sound out. Even though, the Denon output info shows multi channel, too.
Even though I am sure I wouldn’t hear the difference, I would like to try the native DSD approach (compared to convert DSD to PCM) …
I will now move the Roon Core from QNAP to the actual ROCK (moving database and license, but keep music files on the QNAP).
ROCK’s kernel was patched to support native DSD. Therefore, it should provide native DSD from the ROCK NUC via HDMI to my Denon, shouldn’t it?
Well - seems that something is still not working properly.
ROCK is now my Core and connected via HDMI to my Denon. But native DSD does not work (e.g. no sound or ‘cracks’).
For the audio setting: what would I select for native DSD?
DSD convert to PCM works, but isn’t what I want
DoP isn’t support by my Denon
And dCS yields cracks as sound (btw dCS stands for?)
Should there be here another option for native DSD?
