ROCK restarting a couple of times at power-up before running stable
ROCK v1.7, Nuc7iBNH.
I notice that the Roon Server Software takes a long time before getting active. When looking at the Roon Rock status (webbrowser) I notice that the Roon Server Software is restarting a couple of times after 18 seconds running. Sometimes it takes up to 4 minutes before the Roon software is running…
Before v1.7 it took less than a minute to be up and running.
Thanks for taking a look at this.
Hi @Benedikt_Gruyaert,
I think the best step here is to enable some diagnostics on your account so our technical staff can get some more insight into what’s going on here.
Hi, I just rebooted my NUC and it happened again just now (11:28 PM CET).
Rgds,
Benedikt.
Made it happen again about 4 minutes ago…
Thanks, @Benedikt_Gruyaert.
Now that I have the timestamps, diagnostics have been enabled on your account. The next time your Core is active a diagnostics report will automatically be generated and uploaded directly to our servers
Hi, Thanks a lot.
For your information, I rebooted my core just now this morning at 9:44 and the same happened.
I usually shutdown the core when not using it…
Hi, Just for your information, I restarted my Core just now at 18:56 CET and had the same issue again.
The team is investigating this still and they are hoping that we can try using a fresh database temporarily on ROCK so we can see if the same behavior occurs. Please see the following steps:
  • Create a backup in Roon VERY IMPORTANT
  • Stop RoonServer from running in ROCK’s WebUI
  • Navigate to your Roon’s Database Location
  • Find the folder that says “RoonServer”
  • Rename the “RoonServer” folder to “RoonServer_old”
  • Restart the RoonServer in the WebUI to generate a new Roon database folder
After you’ve done the above, try reproducing the issue. Does it still occur? Can you make a note of the time it happens if so?
Hi,
I just did as you suggested (23:20 CET) and the issue is still there.
Best Regards,
Benedikt.
Hi,
Do you have any update ? I leave my NUC running so you have access to it.
Best Regards,
Benedikt.
PS: Since the problem was not solved with the new install I reverted back to the old folder
I met with the team to discuss this today. The technical team is currently doing some testing on this issue in-house. I don’t have any specific updates at the moment, but the team is hard at work trying to reproduce this issue. I’ll be sure to reach out as soon as I have further feedback from the team once they’ve completed their investigation.
Hi @dylan,
My Best Wishes for 2020!
Are you making any progress with this issue ?
It takes about “3 minutes, 51 seconds” to have a proper (re-)boot. Everytime the ‘Roon Server Software’ reboots after 18 seconds, so at least 10 reboots are happening before running stable…
I checked out internal tracker and see that there are recent updates on this ticket from our QA and development teams. I don’t have any specific updates for you just yet, but the team is actively working on this and I hope to have news for you soon. You have our apologies for the ongoing troubles, and your patience has been much appreciated!
Happy New Year!
We’ve recently released RoonOS (Build 186) which includes changes that should improve this behavior. Please give it this a try and let us know how it goes!
You can read the full release notes here:
Thanks,
The Team at Roon Labs
Hi,
Thanks for the update! When I look at my NUC I see that I have Version 1.0 (build 183).
How do I get to build 186 ?
Thanks,
Benedikt.
Use a web browser to connect to the Web Administration Interface, and then click the Reinstall button. That should pull down the latest version of the ROCK OS and install it. Your Roon database settings will be preserved.
Hi,
Found how to update…
It works perfectly. I can confirm the startup is smooth and the loops are gone !
Thanks a lot !
