rooDial a Wireless Volume Knob for Roon with Microsoft Surface Dial
Hi @Martin_de_Vries,
I understand your impatience as I have already announced it :wink:
Right now I’m working on rooMax, a Roon extension that allows using the QuickKeys controller with Roon. It offers eight pushbuttons in several levels whose functions can be individually adjusted. You can be excited. So I’m training a bit regarding the layers :+1:
After having released that I will start working on the upgrade for rooDial. But that will probably take a while because I still have some private things to sort out in the meantime.
Best DrCWO
Hi @DrCWO,
Yes, a bit eager to get such a nice feature indeed which is ofcourse a compliment :slight_smile:
Actually you get me even more eager as I am also very interested in QuickKeys support. Intend to buy one once you have it ready so you couldn’t make me more happy :slight_smile:
Wish you all the best and thanks for your great products, I use most of them.
Is rooMax going to include volume control on the non-Roon ready RME and miniDSP devices?
RME yes if you use rooADI. miniDSP still waits to be implemented some day
Best DrCWO
Ich benutze seit MĂ€rz den Roon Nucleus mit RooExtend und RooDial mit Mircrosoft Surface
Nach lÀngerer Pause funktioniert nun RooDial nicht mehr.
Es fehlt bei Roon unter Erweiterungen.
Die Bluetooth Kopplung funktioniert auch nicht mehr.
Ich habe schon alles neu gestartet etc.
Ist es eventuell eine Frage der Lizenz?
Wo/wie bekomme ich eine Dauerlizenz
MfG
Reinhold
Translation
I have been using Roon Nucleus with RooExtend and RooDial with Mircrosoft Surface since March
After a long break, RooDial no longer works.
It is missing in Roon under Extensions.
Bluetooth pairing no longer works either.
I have already restarted everything etc.
Is it possibly a question of the licence?
Where/how do I get a permanent licence?
MfG
Reinhold
Wenn Sie bereits eine Lizenz haben, benötigen Sie keine andere. Versuchen Sie zunĂ€chst, Ihren Raspberry Pi neu zu starten (Ausschalten und dann hochfahren) und ĂŒberprĂŒfen Sie, ob das fĂŒr Sie funktioniert, die Erweiterung sollte wieder angezeigt werden. Dann koppeln Sie die OberflĂ€che neu. Wenn ein Neustart nicht funktioniert, können Sie versuchen, Ihre SD-Karte erneut zu flashen und dann den obigen Vorgang erneut zu versuchen.
Translation.
If you already have a license you won’t need another. Initially try rebooting (Power down & then up) your Raspberry Pi and check if that works for you, the Extension should reappear. Then re-pair the surface. If a reboot doesn’t work you could try re-flashing your SD card then try the above process again.
Any reports on RooDial working on a Pi 3?
I have used RooDial for some years without any hickups with a RP Zero W.
I realize that RooDial has been an upgraded to 3.x and purchased a RP Zero W2 to perform the upgrade.
I revoked the licence on the old setup and “etched” v3.3.3 on a new SD.
After SD is installed in the new RP Zero W2 it seems to start up as it should, I can configure it to the WLan and it is visible in ROON extentions.
But I expect strange behaviours. Main challenge right now is that it disappears from Roon extensions after a minute or so.
Questions:
1: In the instructions it states that there should be a red led on the board. Is this the case? I have not seen any red led and have just waited until the green led is off before restart of RP.
RooInstruction
2: How should the W2 board indicate when up and running? Mine keeps blinking green when it is visible in extensions. And after a minute or so, the led starts to blink faster (green) and then disappears from Roon extensions.
After additional 30 sek or so the led is fully on (green), but keeps to be invisible in extensions.
A reset of the RP just repeats above.
I have re-etched 3.3.3 several times on different SDs, and changed USB power feed. Same behaviour. I suspect a faulty RP board. Or could it be something else?
I have returned to my old 2.3.2 setup with the RP Zero W. Works perfectly.
Please advise, TiA.
There should be a red led visible unless there’s a problem with the main board
This may be of use
Thanks @PixelPopper
This helps.
I do not have any red led indicating anything on my board.
Initially extensions are visible in Roon, but when activating the services the green led starts to flash (read/write) and then it starts to be solid greed (indicates SD card failure).
At the same time the RP disappears from ROON extensions
When re-etching the SD card with 3.3.3 it fails.
One idea was that I again add a brand new SD card and do everything over again, but the fact that I do not have any red led indicating on the RP board make me draw the conclusion that the RP is faulty and might be the one destroying the SDs.
Project upgrade RooDial is on pause for now.
It’s easy enough to check for the presence of a second LED (even if it’s not working) on the main board as they are located next to each other.
I have identified the led - it is at least physically there. But it does not lit. I guess the RP will be archived (in the bin).
:confounded: 10/characters
Hi there,
I had a similar problem with the extension vanishing, (more coming and going, unstable) and resolved this by disabling IPV6 on the Roon server.
Seemed to me like the Raspberrry PI on IPV4 could not get a stable connection to a Roon server running both IPV4 & 6.
I even switched from Linux to Windows at the server end which made no difference. Went back to Linux Roon server on IPV4 only and it’s been stable for months now.
Hi @Johan_Engwall,
I apologize for my late reply but I’m in the middle of moving from Salzgitter back to FĂŒrth. So I was out for one week but now I’m back to help.
You did anything right. In the Zero W2 there is a green LED and if it is blinking once per second anything is fine. This is also the case if you see rooExtend in the Settings/Extensions of Roon.
There is a simple way to diagnose where the disconnect comes from. If you open a browser with the IP number of you Zero W2 you get to the so calles “Service Page”. At the bottom of this page you find this button:
Please click it right after a disconnect and e-mail what you see to info@definiteaudio.de
I will analyze and give feedback.
Best DrCWO
@DrCWO I couldn’t resist and bought a Quickkeys device upfront. Feels and looks like a quality product. Any indication around what time you expect to release it or maybe do a public test?
Hi Martin,
good decision. It will become a wonderful remote for Roon :+1:
Regarding the release date:
As I moved from Salzgitter to FĂŒrth last week there is so much work that has to be done at the moment. This means time for development is a bit limited now. I hope I will have a first beta for testing till end of June.
Hope that helps :wink:
Best DrCWO
Great & thanks, looking forward to it. Hope you like your new place.
It is a beautiful, open loft with a large balcony terrace.
The best thing: No neighbors that I could disturb with loud music:+1:
I like it very much :grin:
Best DrCWO
Specifically for rooDial, what hardware have others chosen from the following set-up/part recommendations found here: “Use Roon with Microsoft Surface Dial”?
Note: I have no Raspberry Pi experience, but I’ve built 2-Windows HTPC’s and am using an Intel NUC as my Roon Server.
From the above hyper-linked list:
  • I’ve chosen to use a Raspberry Pi 4.
  • Besides the Pi 4 B board (with 8BG of RAM?) what other parts have others bought for rooDial and have been satisfied? Specifically what:
  • Case:
  • Is a Fan Necessary &/or recommended?
  • Power Supply: Is the “Raspberry Pi 15W USB-C Power Supply” satisfactory? Or, for some reason, have others used something else
  • Re. Micro SD, min 8GB Class 10 Card (some kits include the Micro SD Card pre-loaded with NOOBS. Do I need NOOBS?
  • I have various USB and Ethernet cables. Are there any other cables necessary or recommended?
  • Will I need anything else?
