I updated to build 193, but I am still having issues with roon not seeing my devices, not my DAC, not even the TV over HDMI. - it was initially after the first update, but is no longer.
I have an ebox pc, SSD, 4 Gb RAM. Processor is an Intel Atom D7200 running at 213 GHz
Same problem with my QNAP. See no audio devices. I thaught this was a Qnap problem, but maybe not then. I may try to see what happens when I install Roon on my HTPC.
Hi @bevan_court ----- I just got word back from my developers that the provided log is actually from 1.2 and not 1.3.
May I kindly ask you to please provide a new set of logs from your core as well as a copy of your RAATServer logs so I can update my report to our developers. Thanks!
I like to send my logfiles as well.
How is that done when I use Qnap ?
I did a search but no results.
We need to find out if is the Qnap that is the problem or not.
As stated before a test installation works ok on a PC, so I’m thinking it’s my Qnap. To be sure I’ve uninstalled Roon on my pc. (HTPC)
I can connect to my local files. My problem is at the moment I can’t see any audio devices.
The other problem is that a Roon Desktop on a local PC, nor the iPad can browse my music. In setup it seems ok. Meaning I can connect to my music on my server.
Further no Tidal playlists is available.
But I can see Tidal by Roon iPad and Roon desktop.
Hi @R1200CL ------ Thank you for the report. You can connect from the finder/windows explorer to your RoonServer share (like you connect to any other share on the QNAP). Open the RoonServer folder (located on that share) and create a zip file of your logs folder. Copy a dropbox download link here or in a PM addressed to me (@support) and we’ll have a look.
I had the same problem, fought it for two days. I run a simple system, ASIO driver out on a dedicated Roon core computer to my DAC. I reinstalled Roon and troubleshot drivers, nothing worked. I finally disabled my System Output and it all works fine now. Roon now sees my ASIO driver and my system now works fine, even with Fidelizer. I run my Roon computer headless over Win10 remote desktop and my musuc is on a Synology NAS.
Hi @c2c2c2 ---- Thank you for the report and sorry for the troubles. You can either share a download link here on the thread or you can send it to me privately via a PM.
@bevan_court and @Redvolt ---- Just checking in to see if things have been stable. Let me know, and if further assistance is needed I will be glad to help.
