It will be interesting to see if the GUI comments are acted upon, specifically the need to be collapsable as I had the impression when I was in early access that it was final testing of release candidates for major bugs.
I think the almost universal agreement on the need for collapsibility shows the need for an alpha test of such major changes.
Prefer to default to collapsed playlist in menu. Really donât want a super long menu by default. Not actually sure I need playlists in the menu itself as well as on a content screen. Likely to be very unwieldy for most I would exect.
Hoping a few performance/stability tweaks snook in.
Yes, settings cog is good⌠playlists in sidebar needs to be collapsable and ideally, to really make it useful, selectable.
If the 3 dot menu in the main playlists page had the option âShow in sidebarâ, I could then select my favourite playlists to appear there. Or, provide the heart symbol for each playlist and only show favourite playlists in the sidebar.
Good suggestions - for those who have a large number of Playlists, having them all appear in the sidebar seems to defeat the purpose of having quick access to themâŚ
Iâm just playing with the folder option, which is really good. I reckon the quickest and easiest fix is to display playlists in the sidebar from one folder called⌠âSidebarâ. Just change the coding to display Sidebar playlists instead of all playlists and job done! This would give good flexibility to the user and keep coding changes to a minimum.
The sidebar folder could be a system folder without renaming privileges and would appear automatically as a destination. Playlists wouldnât be exclusive to the âSidebarâ folder and could be in Electronic folder as well for instance.
Edit⌠and while weâre on with suggestions. Use thumbnails from album covers from the playlists in the folder rather than just a blank folder image
Only playlists in the âQobuz playlist folderâ can be two-way synced back to Qobuz?
The playlists in the âQobuz playlist folderâ canât be organised into sub-folders in Roon?
It would be useful if you could share (sync) any of your playlists, regardless of where they lived in Roon back to your chosen streaming service(s) â make a simple âsyncâ checkbox/icon (and maybe + platform). If the playlist originated from your selected streaming service, it would just be kept in sync. If it didnât already exist, it would be created and synced going forward. Otherwise you risk ending right back with a single overwhelming folder of playlists in order share/sync them.
That also opens up an avenue for the two-way âsyncâ for a single playlist to work with multiple streaming providers, even those outside of of Qobuz/Tidal.
Yes, but having it on the playlists would greatly increase its potential. Now the playlists are like a box that you manually decide to fill or empty by choosing songs directly, and thatâs okay. But being able to create dynamic playlists that automatically fill or empty according to one or more criteria, would be a game changer.
If, on the other hand, you want to have bookmarks do this, you need to enhance this section because now it is not very friendly ( and implement them in ARC)
I see a lot of tracks listed as unavailable even though play just fine in the Tidal app. I never really use playlist before, so unavailable could have always been a problem.
Also, would be nice if roon search could find the user created playlists that are offered on the streaming services. Like I did a search for John Hughes in roon and just finds the one I already have. But if go to Tidal, there are about 30 matches.
I also agree about being able to collapse the playlists on the sidebar. And why is the list in some random order, should be alpha or allow us to change sort order. But do like the new look of the sidebar and that settings always on the top. Itâs a nice start.
This was always an issue if your streaming service âdroppedâ and re-catalogued the track with a new ID.
Except I just went to look at a playlist that was working fine before lunch, in fact it was a new playlist I was making to test the new playlist features and one of the tracks I explicitly remember playing on that playlist is now unavailable as are several other tracks I added this morning.
I then went back to the playlists I copied those tracks from and noticed a huge number of tracks on those playlists are now also showing as unavailable.
I guess Qobuz could have done a massive catalogue reshuffle today? But it appears Mike is seeing a similar issue with Tidal? Has Roonâs master index changed dramatically today?
If I go to the album (often a local FLAC copy) that contains the track that was previously part of a playlist, it no longer shows the track as being part of any playlists. Trying to find a concrete example where the local track was never likely to have been on a streaming service to start with, to see if this is linked solely to tracks added via a streaming service or local FLAC tracks too.
In fact I am now wondering if I should revert to an older backup while I can, as I really donât want to have to fix all those playlists manually, linking each (now âunavailableâ) track back to itâs local FLAC copy, by hand. Would appreciate a steer here from the Roon team?
(btw. not really fix for the above case, as I want the tracks linked back to the local FLAC version if available so I can download the playlist in ARC for offline listening, but I could have sworn I saw a âfix unavailable tracksâ (against your streaming service) right-click menu yesterday, but maybe I just imagined it!)
My example was one I just added after the update. Its tracks are working within Tidal but show unavailable in roon. So whatâs the point of bringing in user created playlists if half the tracks donât work?
I see your point about Qobuz. I just dropped them because having so many issues with the favorites. Had so many dups and when tried deleting, they keep coming back. Library seems fine with Tidal.
Now I havenât tried the dual sync feature of creating a playlist myself and then seeing it show in Tidal. Iâm not a big playlist person other than liking other peoples playlists. So would really like that part fixed. Whole point of for roon is to work better than native app.
Just realised your second screenshot is Tidal, thatâs even stranger.
So thatâs a playlist:
Created in Tidal
Synced back into Roon from Tidal [automatically]
Still working fine in Tidal
Tracks now showing unavailable in Roon
With you, that makes no sense
(my use case was a bit more complex (not sure âcomplexâ is the right word, butâŚ) in that a playlist I created in Roon (and Roon alone) is now showing a number off itâs tracks as unavailable, yet this morning those tracks were playing fine. I know as I remember playing them off this newly created playlist).
I wonder if Roonâs master catalogue data (from Tidal/Qobuz) has gone adrift today?
So not sure if I got this right. If I make a new playlist in roon, I should then be able to see it in Tidal? And even if use a local track instead of one from Tidal? How long does it take to show up in Tidal? I do see Tidal has a few sort options available for their playlists like alpha, date added, date modified, so those would be welcome to roonâs playlist settings. Also see they offer folders, so even better. If any of these are already available for roon, please let me know.
I do see some sort options in roon once in main playlist section. However now when I go there Iâm only seeing 2 playlist instead of them all like I see on the side. Oh, never mind, show 2 made in roon and then Tidal icon for ones direct from there. As said, never really used playlists before even though had roon for years. Mostly because if made playlist in roon, it wouldnât show up in streaming app like this new update is supposed to do.
Sort options in playlists have no effect on the sidebar order, so that needs to be fixed.
I have several heterogenous playlists, with tracks from my local library, Qobuz, and Tidal. I recently dropped Tidal, so now those tracks show as not available, although they are likely available in Qobuz (100% of my Tidal library syncâd to Qobuz via Soundiiz. is there a straightforward way to sync the missing tracks in a playlist to a different service?
But am I correct in thinking that will only work if your playlist tracks are available in Qobuz?
What happens when you have a hybrid playlists made up of 50% streaming and 50% obscure records and vinyl rips that only exist as FLAC files in your local library?
It feels like something has really screwed up with playlists and track availability (at least for me) today, see above, which feels a bit concerning given how long I spent putting some of them together.
