Roon 2.75 Build 1725 incompatible with Roon Audio API for rooExtend and Victrola Stream (ref#JF67RG)
· I upgraded to the latest Roon 2.75 Build 1725 and the Roon Audio API did not work any more!
I was able to test the same on a second Roon server around here that still has the 2.74 build 1719 ans it nicely works!
This not only affects my rooExtend Roon Extensions but also the Victrola Stream turntables which also use the Roon Audio API.
I already posted the issue in my rooExtend Thread:
Best DrCWO
· Not necessary
My curent finding is that in Build 1725 local IP numbers for the mediaUrl are rejected.
If I reverse DNS them to a local domain name it works. @RBM also checked this on Build 1726 and says that it works there with the local IPs but I can’t test as I don’t know how to upgrade…
Hi @DrCWO
Thank you for the report. We’ve gathered logs and will escalate to engineering to take a look.
Hi @connor
Here an analysis of my logfile. First line ist the line number in the logfile, second line the content. It clearly shows the issue:
If media_url is http://develop.local/audio it works, if http://192.168.0.193/audio it fails.
17661
11/20 09:37:36 Trace: [roonapi] [apiclient 192.168.0.193:58586] GOT com.roonlabs.audioinput:1/play {"session_id":"c668fa16aa784fc484d738aaf2a189b6","type":"channel","slot":"play","media_url":"http://develop.local/audio","info":{"is_seek_allowed":false,"is_pause_allowed":false,"image_url":"http://192.168.0.193/images/speaker_dark.jpg","one_line":{"line1":"rooDRC\nChannel check"},"two_line":{"line1":"rooDRC\nChannel check"},"three_line":{"line1":"rooDRC\nChannel check"}}}
17707
11/20 10:00:24 Trace: [internetradio] Channel Player: Fetching URL [http://develop.local/audio]
18197
11/20 10:03:07 Trace: [roonapi] [apiclient 192.168.0.193:47050] GOT com.roonlabs.audioinput:1/play {"session_id":"7a4de9ceb5df475e9ae475e781e9f857","type":"channel","slot":"play","media_url":"http://192.168.0.193/audio","info":{"is_seek_allowed":false,"is_pause_allowed":false,"image_url":"http://192.168.0.193/images/speaker_dark.jpg","one_line":{"line1":"rooDRC\nChannel check"},"two_line":{"line1":"rooDRC\nChannel check"},"three_line":{"line1":"rooDRC\nChannel check"}}}
18244
11/20 10:03:08 Warn: [internetradio] refusing blocked channel URL [http://192.168.0.193/audio]
Hey @DrCWO,
Thank you for the detailed log analysis.
We’ve added these findings to the ticket with our development team. That includes the impact on Victrola Stream owners, who can’t change the URL their turntable sends.
Until there’s a fix, using a hostname in media_url (as you did with develop.local) is a sound workaround for rooExtend. We can’t yet confirm which build will contain the fix, so we’d hold off on pointing anyone to build 1726 until we hear back from the team. We’ll update this thread as soon as we do.
Hi Benjamin,
thanks’ for the update.
I pushed out rooExtend v3.6.1 yesterday fixing that.
It was a bit critical as since v3.6.0 I published Easy To Use Reference-Grade Digital Room Correction. that relies on the Roon Audio API working for recording the Roon measurement.
Nevertheless I hope you will find the issue and fix it soon.
I also have a second ticket open regarding a memory leak in RAAT server.
Memory leak in Roon Bridge RAAT server causing performance issues (ref#TE8Y8F)[Ticket in] - Support - Roon Labs Community
Hope this is also still ta your list.
Best DrCWO
Hey @DrCWO,
Thanks for getting rooExtend v3.6.1 out so quickly, and for confirming the hostname workaround works on your side.
We’ve added the rooDRC dependency to the ticket. Measurement recording relying on the Audio API makes this more urgent, and the development team now has that context alongside the Victrola Stream impact.
We’ll follow up on the RAAT memory leak in its own thread (ref#TE8Y8F) so the two issues don’t get mixed up here.
Once a build with the fix is confirmed, it’ll be included over in our Software Release notes category. :+1:
