Eero Pro router, wired connection to Diskstation (core) through Netgear S8000 switch, WiFi connections to NAD M10 and Bluesound Node 2i
WiFi connections to NAD M10 and Bluesound Node 2i controlled by Android phone or Windows 10 laptop.
When I stream music file through Roon I am regularly getting messages that Tidal media or an audio file from my library are loading too slowly and as a result Roon skips to the next track (and may skip through a few tracks) before playing. If I hit the back/reverse button, Roon will play the skipped track (most of the time). If I hit the forward button on a playlist or an album on Tidal (and from my own library), I can also get the same problem. Roon will skip tracks due to slow loading of the music file. I’d say the problem occurs 50% of the time.
I even have problems with to Live Radio. Roon stating the URL doesn’t exist anymore when I click on a radio station link and when I click the radio link again, Roon connects to the radio station!
Once Roon is playing an album, it is stable most of the time. But if I change albums or try to skip tracks, there is inevitably a problem. Also, when an album finishes and Roon Radio starts, tracks will also be skipped here continuously. I have same issue with Tidal playlists.
I do not see any of these problems when I control the NAD M10 and Bluesound Node 2i using the BluOS software on my phone or laptop. It is rock solid, I change sources, skip songs, etc and the connection/streaming is immediate.
Do these same issues occur if you play to an endpoint besides the Bluesound devices? If you play to System Output of a remote for example do you see any of the same errors?
Hi Dylan,
I didn’t think of trying that. I enabled my Samsung phone and Roon seems to be quite stable when I use it to play music on the phone. I have had no track skipping etc so far. I have used Tidal on Roon and switched very quickly to different albums and songs on their playlists with no problems. If I do this on the BluOs systems, using Roon I have problems.
Hi,
I forget to mention that sometimes the BluOS units disappear from the Roon audio device listings and then return miraculously about 30seconds later, possibly longer! This happens when the track skipping occurs but not all the time! Roon always finds the BluOS units when I open up the software.
Hi,
The issue still persists even though it appeared more stable yesterday than this morning for some reason! I will try to connect the units by Ethernet cable but it won’t be today as I’m too busy. I will have to disconnect the units and bring them into a room where one of EERO routers are.
Hi,
I see on another post that Roon have been able to replicate the issues that a number of us are seeing when using Roon with WiFi connected BluOS devices. I’ll hold off then on any further experimentation at home until Roon hopefully come up with a solution.
Yes, that is correct. We’re working with Bluesound to resolve these issues on WiFi, but do know that it will take a significant amount of time until changes are made in this area, it will require collaboration between us and BluOs. My suggestion would be to use Ethernet for the time being.
Hi,
I’ll struggle on with the WiFi for now. The problem is annoying but it’s not the end of the world. There are far more concerning problems in the world at the moment.
Okay. I was bored this weekend so moved one of my Eero Pro routers to beside the NAD M10. WIth an ethernet connection, Roon behaves and there is no skipping tracks etc.
Take the ethernet cable out, use a WiFi connection and the Roon connection is not stable. Tracks skipped, the Nad M10 disappearing from the available player list, etc,
Thanks for the update here, since Ethernet works as expected, I would continue to use this connection method until the Bluesound investigation is complete.
