Roon and miniDSP SDH - Not playing issue (ref#N9DP0U)
· The System Output has *no problem*, it's only my other Zone.
· Network - Ethernet
· RoonReady
· Yes, it shows up there, but it isn't Enabled
Does the "Enable" button unlock the Zone?
· I pressed Enable, but the Zone remains disabled
· Only one output type is affected while the other output type works as expected
· Worked yesterday. Not today.
· minidspSDH affected. No other zones.
FiberOpticModem--ethernet-->Roon Rock --ethernet--> SDH.
Hello @Jim_Bohlman,
Welcome to the community! Thank you for sharing the details of your setup and the specific behavior you’re seeing with your miniDSP SHD.
Could you please try restarting your Roon Server (your Roon ROCK machine). Does a full reboot of the server restore playback?
We have seen some similar reports following recent updates, and knowing if a restart temporarily resolves the issue will help us determine the next steps.
Looking forward to your reply.
OP here.
SDH zone is enabled as Roon Ready in Roon remotes (desktop and iphone app), but will not play. Attempts to play a song, no countup of seconds of play, advances to next song in list/album, wont play that, advances a few ore times, then gives “Too many failures. Stopping playback” message. Other sources play to the SDH (Tidal, Aple Music). Roon also plays to other zones (Escape P6 Air and iPhone direct). Did not work either before or after application of most recent SDH firmware.
Rebooting the Roon Rock server fixed it.
I didn’t think the issue was there because it played to other zones… but that did the trick.
Thank you!
