Not relevant
Hiby R5 any Android device
Roon on Android has very high battery consumption I have found on any Android device. If left running but ideal it continues to drain the battery on device as much as if I was using app. I get constant notifications from OS that Roon is draining power to. I don’t get this from any other app to the same extent. Is this a known issue with Roon on Android?
I’ve been noticing similar behavior. My phone will drain 40% of the battery while I’m listening to music for half an hour. I’ll select an album and leave my phone alone with the screen off.
This is for remote usage. My phone is a One plus 6. It only takes a few minutes for my phone to get hot to the touch.
