“external_ip”: {“actual_external_ip”:“aaa.cc.xxx.zz”,“router_external_ip”:null},
“upnp_autoconfig”: {“server_ip”:“192.168.2.1”,“found_upnp”:true,“error”:“Did not find UPnP service with WANIPConnection on network”}
Canada - Bell Home Hub 3000
Roon core software running on MacBook Pro via wifi
Apple HomePods
6210 tracks
Cannot connect to Roon ARC outside my home (I can connect when I am at home and on the same network).
I contacted my service provider to see how to open a port - apparently it is not possible to configure the router.
How do you suggest we proceed to resolve this issue?
Please accept our apologies for the long delay in responding to your initial inquiry. Were you able to enable mobile playback with ARC with your Home Hub 3000?
If you have a second router in your setup, then you’ll need to follow the steps suggested in this thread to safely configure the second router as an “access point.” Please let me know if we can provide assistance and we’ll be watching for your response.
