Roon ARC not displaying artist discography
Roon Nucleus+
iPhone Xr iOS 16.3.1
118,040
In Roon ARC, the Discography tab often doesn’t populate. This has happened for quite some time, but I am now just reporting it. The Overview tab reveals the albums, but the discography tab is blank.
Above is an example of an artist that is on Qobuz. No local files. Below is an example where I have many local files.
Hi @TuliaNonTroppo,
We had a known issue regarding the Discography page in ARC. Are you still encountering this issue on the most recent build? If so, what happens if you change the sorting?
We’ll stand by for your response. Thank you!
Hey Connor!
After some time to test this, I haven’t had another issue where the discography has not loaded for me. Thank you for addressing this, and I consider this issue resolved.
Cheers,
Christopher
Hi @connor , Nick Lowe is not coming up for me just now. Time stamp in image:
UPDATE - not sure if you did anything, but when I changed the sort to “by popularity” it populated. Changing it back to “by release date” kept it populated and sorted it to my preferred way of seeing the discography. I hope this helps!
@connor , I found the same behavior today with Izo FitzRoy discography. It initially did not show on the “by release date” sort but immediately popped in when changing it to “by popularity” then stayed (but correctly resorted) when changing back to “by release date.” Hopefully this narrows down the issue!
