Trying to connect but to no avail. I’ve turned off ipv6 but all I get is this message
“external_ip”: {“actual_external_ip”:“xxxx”,“router_external_ip”:null},
“upnp_autoconfig”: {“server_ip”:“192.168.1.254”,“found_upnp”:true,“error”:“Did not find UPnP service with WANIPConnection on network”}
Any tips?
@Phill_Reilly, please complete the following support template. Thanks.
<!-- Include your operating system and machine info (Model, CPU, RAM) -‐>
<!-- Write below this line -‐>
<!-- Your network gear (model of routers/switches) and if on WiFi/Ethernet, are you using YPN -‐>
<!-- Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.) -‐>
<!-- Tell us how large your music library is, eg. “30,000 tracks” -‐>
<!-- Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated! -‐>
Solved it- I needed to manually enable port forward and name the port 55000
What steps did you need to take to manually configure port forwarding? Thanks
@Phill_Reilly, if you can share the router model number and the steps you’ve taken, this can be added to the knowledge base, and will help other community members.
See below mate
This worked for me….
Bt Smart Hub 2
Access hub on web page…type http://192.168.1.254/ in search bar
Go to advanced settings/firewall (enter admin password - can be found on card at back of hub)
On “configuration” tab ensure upnp is enabled
On “port forwarding” tab click “create new port forwarding rule”
In boxes left to right type a rule name of your choice / eg Roon ARC / choose the IP address of your core or device name from drop down box / 55000 / 55000 / 55000 / 55000 / TCP
Click + and Save
Bingo!
Perfect! Ta
