Windows 10 virtual machine running Roon Server (and nothing else). Server set up via ProxMox. Static IP. Firewall disabled.
Roon version 1.8 (build 756)
Router: Ubiquiti AmpliFi HD
Roon Server: Windows 10 virtual machine set on a static IP. Windows firewall disabled. No other additional programs installed. Connected to the network via ethernet.
Media files: Located on a Synology NAS with a static IP.
Roon devices: Schiit Modius connected via USB to a desktop computer with DHCP enabled. MiniDSP SHD connected to the network via ethernet with a static IP.
ALL devices are on the same physical network and the same subnet.
Audio Device 1: MiniDSP SHD. connected via ethernet.
Audio Device 2: Schiit Modius. Connected to desktop via USB.
Good afternoon!
Recently I started having an issue with one of my audio devices and Roon. When I go to play a track, it appears to attempt to play the track, fails, skips to the next available track, fails, ad infinitum. This only recently started happening on my desktop computer with my Schiit Modius. Both my MiniDSP SHD and my cell phone are able to play both Tidal and library files through Roon just fine. the Modius also serves as my primary audio device for this computer, and is working just fine. Roon clearly sees the Modius connected to my computer. When I changed USB ports, it re-connected to Roon and now it seems to work…
Could it be something to do with Roon expecting the device to appear on a particular COM port? I have disconnected and re-connected a few usb devices recently. I’m unusure if the Modius was disconnected as part of that. Should I note which COM port it is on and be sure to make sure it always on that particular one?
What I tried:
-Restarting the desktop with the Schiit Modius
-Connecting and re-connecting the Schiit Modius
-Restarting the VM (Roon Core)
-Restarting the VM Server
-Connecting the Schiit Modius to a different USB port (FIXED THE ISSUE)
Thank you for your time and assistance!
