Roon Backups and WiiM Pro Endpoint Disappearing Issue
Nucleus B
Eero Mesh, Nucleus, and all endpoints wired back to an unmanaged Netgear switch uplinked to Arris cable modem/Xfinity.
NAD CS1 Optical to Schiit DAC
Raspberry Pi 4 USB to Schiit DAC
WimM Pro (Problem device) Optical to RME DAC
All 3 devices wired/ethernet to Nucleus (via common Netgear switch)
16K
So lately (since the last WiiM firmware update perhaps?) my WiiM Pro Roon endpoint has been disappearing from available Roon audio devices. When the WiiM Pro dissapears from Roon, network connectivity (both WiFI and Ethernet) is maintained, all other streaming functions work, including Airplay from Roon. It is just the ‘Roon Ready’ WimM Pro audio device that disappears (seemingly randomly). A reboot of the WiiM Pro brings the endpoint back and visible from within Roon. I performed a ‘Restore Factory Settings’ to the WiiM Pro no change. I have however now found a pattern to the issue and can replicate it. Every time a Roon backup runs (in my case every 4 days) the WiiM Pro Roon Ready Audio device disappears from Roon and requires a reboot to make it visible again.
This issue does not affect any of the other Roon endpoints I have (Raspberry Pi4/Ropiee, NAD CS1 etc.) Only the WiiM Pro.
I have experienced the same issue. Wiim remains available only via Airplay. A reboot of the Wiim resolves the problem
Brand new Wiim Pro which disappeared from Roon but seen as Chromecast and Airplay device. Power On/Off and is Roon available device.
Apparently not an isolated incident.
Having the exact same issue, hoping for a software fix from Roon or Wiim. Have you revealed the issue to Wiim?
Yes, I opened a ticket with WiiM support who are reviewing logs etc.
WimM Pro & Roon Backup Issue. | WiiM (wiimhome.com)
I have the exact same issue. Sometime it takes just 15 seconds and the Wiim Pro stops playing and disappears from Roon. :frowning:
So a scheduled Roon backup ran at 2am PST today, and like clockwork the WiiM Pro disappeared again from available Roon endpoint devices (still shows as an AIrPlay device, pingable on the network, accessible from the WiiM app etc.).
Roon @support, any additional information required?
Hi @Wakajazz and others experiencing this issue,
Thanks for writing in! @Wakajazz thanks for sharing that timestamp, we were able to review a fresh diagnostic report from your core, and see the exact thing you describe in your report.
With that, we’re not seeing any errors or anomalies that may cause this disconnect. I do see some interesting behavior with the WiiM Pro trying to connect via Chromecast and failing. You could try temporarily disabling this as an input option and see if your issue persists.
We’ll have our development team take a closer look at this as well. In the meantime, let’s do a refresh of your RAATServer database just to make sure we’re running on a clean slate while troubleshooting.
You can generate a new RAATServer instance on your device by following these instructions, but please be aware that this will reset your Roon Settings → Audio Tab to factory settings and I would advise making a backup of any custom DSP settings you have:
  • Create a Backup of your current Roon Database
  • Stop RoonServer from running in Nucleus’s WebUI
  • Navigate to your Roon’s Database Location
  • Restart the RoonServer in the WebUI to generate a new RAATServer
Let me know if the issue persists after refreshing the above. Thanks!
Thanks @Benjamin, followed your instructions. Chromecast was not enabled on the WiiM Pro, however I performed a factory reset to be sure.
Running on a new RAATServer instance now. Performed a full restart on the Nucleus after renaming the RAATServer folder and the RoonServer start/stop, just to be sure.
I’ll update you in a few days.
Hey @benjamin, quick update. Since applying the above procedures, the WiiM Pro has remained solidly connected to Roon Core having survived multiple scheduled updates over the past week.
The only other change that I was made aware of is that a firmware update (4.8.526344) had applied to the device during this time. The release notes include " * Fixed - Occasional crash issues for AirPlay 2 and Roon Ready".
Thank you for assistance.
Hey @Wakajazz,
I’m so glad to hear it! Happy listening :musical_note: :metal:
